this might be a stupid question... when the key is out of the truck for a long time, is the radio suppose to work?
I am trying to locate a parasitic draw to the battery. my problem is there is power in the hitch now all the time, it used to shut off after a moment after taking the keys out.
power in the hitch connector should turn off after awhile correct?
No, it does not shut off. The 12V provided to the 7 way socket should be hot all the time.
I just checked my truck, haven't driven it, pressed any key fob buttons or opened any doors since last night. It shows 12V to pin 4.
Sent from the demons in my head
The radio does work for a while after removing the key and even after opening the door. Maybe to not drop calls if a call was in progress when shutting off the truck?
I still see GMC Intellilink in my phone's Bluetooth for a while after shutting off the truck and getting out sometimes. Kinda annoying actually.
One time after a phone call I took through the truck's radio, it got stuck thinking the call was still active, unable to hang-up, even after powering off my phone!
I had to remove the key and leave the driver's door open for 5 minutes to resolve it.
Not sure if any of that is on point but evidently the radio is alive after removing the key and opening the door.
The 12V 7 way plug should always be powered.
