I recently purchased a used 2013 Silverado and I'm having a few problems with it.
The light for cruise control comes on but doesn't actually work. I googled the issue and everyone says to replace the brake light switch so I went on amazon and ordered one.
But when I went to install it I found there was no switch and no harness. The bolt and clip that secure it to the pedal are present but the switch was taken off. Instead all I have are these wires hanging out by my feet.
It's odd and I'm hoping one of y'all could clue me in on what these wires are for. I'm not sure if they're actually even for the brake light switch.
Thanks
I am going to say that there use to be a trailer brake installed, and was removed.  those are the wires.  i bet you dont have brake lights either.
i cant find a wiring diagram either thats color coded to help - sorry
right around the 40 second mark in this video, you can see the wires
Edited by Bleepster
Someone cut the switch out. Std gm setup has the switch controlling brake lights (1 pair of wires , normally open, routed thru relay) and cruise control (other pair of wires). The cruise circuit might be normally open or closed depending I the engineers creativity that day of design.
From what Ive seen none of the trucks with the black brake light switch have this white switch and vise versa. My truck doesnt even have a receiver hitch, just a ball on the bumper
My Yukon has the switch, my Sierra does not.  Both have the Integrated Trailer Brake Controller.  Those wires in the first post are for an aftermarket trailer brake controller.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   5 Members, 0 Anonymous, 2,189 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
