I just got a 2019 Silverado trail boss.  It came with a sports bar and a hard bed cover. The issue is I cant open the bed cover because the sports bar is in the way. Since it angles in, the 1st flap of the bed cover hits it and wont open.  The guy at Chevy said that even a soft cover wont work because those tracks stick further out on the side and it would be pinned under the sports bar mount. I'm not really looking to spend 2 grand on a retractable one. Any suggestions?
You still won't be able to open all the sections, but what about a hard folding tonneau that mounts with rails inside the edge of the bed?  I'm thinking something the UnderCover Ultra Flex that I have.  The mounting rails are inside the bed rail and only the weather seal sits on top of the bed rail.
I"m no expert, but I'd guess you need to choose between retractable tonneau with the sports bar, any tonneau you want but no sports bar or some limitation that the sports bar imposes on the tonneau.
I just installed an Access original roll-up on my AT4.  It installs on the inside of the bed rails and rolls up like 6-8" tall .
Unless I'm missing something, I don't see why that wouldn't work on yours and they are less than $500.
Thank you.  What I have now is a hard folding tonneau cover. But as you said I cant open the cover all the way.  Only the first flap will open.  It looks like I have to get rid of the the sports bar even though I really like the way it looks.
Chevy dealer said that for the 2019 they don't make the rollup covers that go inside the bed.  it will sit under where the sports bar is screwed into the bed.
Edited by Jag2000v
Your dealer is mistaken as various aftermarket companies have rollup tonneau covers for the 2019+ GM trucks.
Check out the websites for Access, Truxedo, etc to find one that would work with your application.
I have a Truxedo Edge for my 2020 TB.
My Access Cover fits inside perfectly.  Now if the Sports Bar mounts to the inside of the bed in any way, it might interfere with the way the cover mounts.  Without a picture of the mounting hardware it's hard to know.  I have seen some posts from Colorado and Canyon owners that have installed a soft roll up cover with the sports bar.
Here's a pic of mine installed with the carbon pro bed and it's inside the bed rails.
Thank you. And this should fit a 2019 Silverado Trail Boss?  Can I have the part number please?
Thank you.  I called Truxedo and explained what I needed and they were able to recommend something for me.  So I ordered it and we'll see if that softcover works.
The soft rollup tonneau from GM Accessories will work. It's about $500.
Thank you.  I just ordered one from Truxedo a few days ago
I was looking at the Chevy soft roll-up cover the other day. How do you like it?
On the Chevy Accessories website, it looks lower profile (like a Truxedo LoPro) than it does on your video.
I don't like it, which is why I didn't get it. I have the Rough Country hard trifold. I wanted something more secure and water resistant than a soft rollup tonneau. That's also not my video. It's one I came across a few months back while researching tonneau covers that'll work with the sport bar. Seeing this thread reminded me of the video.
  • Thanks 1
I have the cover from Chevy , it came with the truck and it leaks and the dealer doesn't warranty it from leaking into the truck .
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 890 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
