So to make a long story short I was having trouble with my cluster in my 2004 Silverado I sent it off to get it rebuilt the guy said he couldn’t get it to act up on the bench but I told him to rebuild it anyways since he already had it. Got it back put it in worked great and now a week later I have no gauges. All I have is the back light and turn signals. Nothing else works on the cluster. Same problem I was having before So I’m hoping somebody can help me and tell me some things I can check so I can get this figured out. Thanks so much
  • txab changed the title to 2004 Cluster issues
I'd be checking all the body grounds, the battery cables/connections and the battery would be load tested
I'm betting there is a solder flux crack/weakness somewhere on the cluster circuit board.  Get a strong magnifying glass and be prepared to spend a few hours going over the thing inch by inch.  There is a user on here sometimes, I think Coby7 who has done cluster repairs on the side and might have some input.
Appreciate the input. I’ll look into that my wife carried it this morning and had a front end alignment done and said the cluster started working on her way home. So it’s just about gotta be a loose connection, ground or a wire somewhere causing it to it.
I hope it is just that!  Check her over good.  (the wires, not the wife, you already did that when you married her, ha ha)
