I have a 2007 Tahoe and it has been stuck in 4wd for a while. Seemed like initially it was intermittent but eventually stayed in 4wd. Fuses checked good and no trouble/warning lights. I started tinkering with it today trying figure out the problem. I felt pretty good about the actuator and decided to replace it. After replacing it I now have a “service 4wd” dash light and the 2wd light is on and the 4wd high light blinks. Unable to change from this condition. Fuses are still good. I do think the actuator was bad but maybe something else led to its failure?
Curious if anyone has had a similar issue or could provide advice on what to check next? Looking for how or if I can test the encoder motor on the transfer case but not finding much out there.
Thanks in advance for any input you might have!
Silly question: Have you scanned for codes yet?
Also, it sounds like it could be something in the transfer case. Maybe something to do with the transfer case shift motor?
1 hour ago, trogers449 said:
I have an appointment tomorrow at the stealership to have it scanned.
You need a Tech-2 to properly work on these things, throwing parts at it is a waste or time and money.  The Tech-2 will would have paid for itself this time and will pay for itself next time, get one.
You are absolutely correct. Its just getting past that “paying for it the first time”. Lol. I think I’ll ask santa!
Best affordable brand and source of a Tech-2?
Bret, Vetronix and Bosch long ago transferred production of these to China.  So the Chicoms make them today.  Mine is from 2017 and is identical to a 2010 Vetronix in function save for the metal PCMCIA slot door.  Anyhow, you'll want one with the last software update, 33.004 and with all the cables for testing and powering it up various ways which you will rarely use but they come in handy.  You do not NEED the software discs or for them to work, it's just nice to have if you can get it working on a Win XP or Win 7 machine.  You also need a Keystone Lite adapter to connect to a modern PC if you want to program modules.
So, you can and should buy them anywhere that has good reviews and customer service.  When mine arrived, the ODBII adapter was faulty but the seller sent a new one right away.  Mine has seen almost continual daily use since and I have replaced the adapters, cable and PCMCIA card and probably need to replace the VCI Module to work on GMT800 style vehicles.  Still it's a tough unit for $350 and some are getting them for much less lately delivered. Guys on the TahoeYukon forum have been picking them up from US sellers on Ebay lately too.
I hear ya there, when I first needed one they were $3500 and was at the mercy of the dealerships to fix it.  Thankfully, I have a very competent one that I can trust nearby when I need them.
    • Disassembly may be Required!   Every blender makes claims but do  you ponder those claims? What was really said? Was it true?  Motive for saying it? What does in infer?  Is that inference true?    Let's do one.    Claim: Made from shear stable base oils.    What was said: Base Oils are shear proof.   Was it true: Yes.  ALL base oils are Newtonian.    Motive / Inference: To imply the fully formulated product is Shear Proof.    Is the Inference true?: Most fully formulated multigrade oils contain Viscosity Modifiers or VM's, sometimes called VII or Viscosity Index Improvers. There are four types. One is in fact shear proof but it also has a bad effect on extreme cold flow and is restricted to use in specialty oils. A second has limited shear called a 0-5 SSI polymer. Meaning its shear is limited to a range of zero to five percent as reported by the ASTM D6278 Shear Stability Index test. A few high end oils, like Torco SR-5, use them and brag about it profusely. Actually all that use it point it out. The last two shear dramatically and are often marketed as a 'feature' of the product aiding the oil to meet fuel standard requirements of ever stricter rules. One shears more than 5% and the other up to 20%. As you make guess, cost is directly linked to shear down and as such the majority of oils use the cheapest organic polymers sold to make grade and pass stringent tests.    PPD's or Pour Point Depressants also shear a bit, only a few percent and hide inside the 0-5 SSI capabilities.    The blender knows he can not out engineer Stribeck. Physics is not a suggestion. But he can wordcraft the unsuspecting toward believing a false claims INFERENCE. This is LEGAL. It is COMMON, and it is EFFECTIVE.
    • I don't recall ever dealing with one on an '06 and back. It may not even exist on that. I can't remember for sure.   Any kind of ice in or after the evaporator is normally due to low charge with both a clutch-cycling orifice tube system, and a TXV system.
    • Engines wear. It is unavoidable. So the question isn't if it will wear out but rather WHEN it will wear out. That question is about rate and RATE is a HUGE problem for almost everyone; but not in the way we may think.    Unless there is something drastically wrong with your powertrain, wear is exceedingly slow. It doesn't wear out in minutes or hours or days or months but in years or even decades. Ditto sludge and varnish. Humans are an impatient lot so to see the benefit of a truly superior product you may have to wait a very long time. Most will get bored first and trade before they reap the benefit.   Humans are not companionate creatures when it comes to those we do not know. We don't care what happens to the second or third owner as long as it doesn't happen to us or someone we know and actually like.   Sad commentary on humans but it is what it is. That thus, then, there is no advantage...to or for you if the above paragraphs adequately describe you.    BUT if you are a buy and hold type and patient enough to reap the rewards of your labors then that thing that is happening that you haven't yet seen, but will; can be abated by such products. Seals harden and leak with time and lots of it. Rings stick after thousands of miles of a slowly building plaque of varnish.    Then there is this. This didn't happen over night and this poor fellow knew when he removed the cover and not one second before.   Not "aware' isn't the same thing as "isn't happening".        The above was typical of the Ford 361 and 391 bus motors on Bulk Pennzoil Mineral Oil products on 3K mile OCI's at about 60K miles back in the 60's and 70's at the Anamosa School District when my Uncle took over their maintenance program.    This is Pepper at @ 165K on 5K OCI's using Group IV/V Full Synthetics.      HM oils will help the first but not the second.    Then again if one used..... ah, ya know.....
    • Thanks for coming back with an update.
    • Awesome you got it sorted! That's a new potential issue I'll have to mark in my book of issues. Thanks for the feedback.
