Any other tuners other than  Range that will disable AFM, I was hoping to just turn AFM off without having to leave things plugged into OBD port
You could also buy HP Tuners and learn to do other tuning as well. If that is in your budget and learning ability.
    zibzer2
    zibzer2
  • Who's Online   5 Members, 0 Anonymous, 830 Guests (See full list)
