Over the weekend, I removed my stock 20" wheels on my Sierra and installed the stock 20" AT4 wheels/tires.  I now have a warning light every time I get in my truck and sensors aren't working.  I believe the AT4 wheels I installed has the sensors still..  Any advice on how to fix this?  I called my tire shop and they said I would have to bring in my old wheels so they can take the sensors off of them and install them on my new wheels.  Is this the only way?  Any help would be great.
If the GM sensors are still in the wheels you just need to reprogram them.  The shop can reprogram them to your truck in a min. No need to remove sensors from other wheels.
Edited by mafd2
I bought the re-learn tool from amazon to do it myself after tire rotations.  Easy.  $11
https://smile.amazon.com/VXDAS-EL-50448-Pressure-Monitor-Activation/dp/B072BK693N/
Go to the tire section of the information display
push and hold the reset button on the steering wheel
horn will honk
go to drivers side front -  push the button on the tool.  Horn will honk
same on passenger front, then passenger rear, and finish on drivers rear.
Horn will honk twice and you are done.
takes 30 secs.
horn will honk
takes 30 secs.
I have a similar re-learn tool.
