JJC Posted October 20, 2020 Posted October 20, 2020 My backup camera view is foggy/blurry, I thought is was the display screen but after cleaning it with screen mom, and removing all the residue from the previous owner, the display screen looks a lot better. Then I cleaned the backup camera lens and the view is still bad. I was thinking if I could disconnect the camera lens and clean inside of it, but that sounds like it might not work. Has anyone had to replace their lens or have another solution to the blurry camera? Thanks
silveradosid Posted October 20, 2020 Posted October 20, 2020 i took the connector off of the camera and found the connections had tarnished, cleaned the pins and the camera is much better. 2 tiny screws to remove the connector
JJC Posted October 21, 2020 Author Posted October 21, 2020 Ok thanks! I will try that and see what happens
JJC Posted October 25, 2020 Author Posted October 25, 2020 no luck with cleaning the connector as it was clean anyways. I will look into a new camera.
Register a new accountSign in
