Looking into some wheel spacers as I’m rubbing control arm after motofab level/ control arm install
what brand wheel spacers do you guys use / trust?
Funny you should ask. I just today ordered a pair of Stahl steel 1" spacers for the rear of my lifted truck from Custom Offsets.
These are the best money can buy. If you want aluminum , BORA is the best. They are the same company. Don't buy eBay junk.
Sent from my Pixel 3 using Tapatalk
I've got a set (4) of BORA 1" spacers that I ordered from Custom Offsets that I used with the stock wheels.  I later replaced wheels & tires and went with a zero offset.  I'd sell the set for $150 plus shipping.  I paid over $250 for them.
Does this size require cutting the stock wheel bolts?
If you are using the stock wheels, there are pockets that clear the original studs.  You'd probably have to trim them if using aftermarket wheels.
A lot of aftermarket wheels have these pockets. Mine do so no trimming the studs .
    contrabombarde
    contrabombarde
  • Who's Online   4 Members, 0 Anonymous, 1,395 Guests (See full list)
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
