I just went to refill my DEF fluid for the first time.  I slightly overfilled it with on a dribble coming over the fill cap.  I wiped everything up from the truck and garage floor and went back in the house.  I came back out to the garage a few hours later and there was a huge puddle of half-dried DEF fluid on the garage floor on the OPPOSITE side of the truck, passenger side between the bed and the cab of the truck.  I looked underneath and saw dried DEF on the side and bottom of the frame.  I have no idea how it leaked so much and how it leaked from the complete opposite side of the truck from where I filled it.  I checked the floor and it did not run from the driver's side.  The floor and the driver's side was dry and fine.  It's like it leaked from somewhere above the passenger frame rail and ran down.  Surely that's not normal, right?
You are not supposed to overfill it. The manual specifies this. I do not know if overfilling it will actually cause any damage. I have filled mine just like you describe, but it was right before a 500 mile trip. Maybe there is a purge valve as I’m sure the lines leading to the def injector have fluid in them that can try to leak back into the tank.
LMAO
how are you not going to overfill it?   There’s no indicator or sound when it’s near full and my crystal ball has been useless lately.
When fluid reaches the top of the DEF fill pipe, stop filling. Do not top off the DEF tank. If using a bottle or
 jug to refill DEF, follow the instructions on the container label and use a dedicated fill aid.
That’s from the diesel supplement manual.
But you can’t see the top of the fill pipe when you have a jug with a nozzle inside filling it! I read that too and that’s the stupidest thing I’ve ever heard. That’s why gas pumps have automatic shut offs. It’s impossible to know when you’re full.
  • 2 years later...
Filled up my new 2023 Silverado 3.0L with DEF for the first time after DIC said I had about 900 miles left. Per owners manual, supposed to fill it up until you see it come to the top of the fill port. While filling, started to hear fluid leaking on the floor on opposite side of truck, looked underneath, all kinds of DEF flowing out on the floor, it never came to the top of the fill port. My friend has the same truck, this has never happened to him. I also drive a 2018 HD2500 with the larger Duramax, you fill the DEF in the engine compartment port, never had any issues with that truck earlier. Will be seeing the dealer on Monday, not impressed with initial call to the service advisor, they told me if it stopped leaking it should be fine.
    • Sounds like converting will be a bigger endeavor than I was thinking. This truck doesn't have 2Hi like the Suburban did. The Tahoe has 4Hi and 4Lo and a button to turn of traction control.   From what I understand the Stabilitrak uses open diff in the front and rear. When wheel speed is not the same the stabilitrak uses the ABS system to slowdown the spinning wheel(s) to transfer power to the slower non-spinning wheel(s). I thought the transfer case was open too. Being able to transfer power either more to front or rear depending on wheel spin. Maybe I miss understood some information with you saying and power transfer is 50-50. Thanks
    • My brother has a 2007 Avalanche with afm 5.3. It`s got 176,000 miles. Runs like a clock. Never been apart. Co worker has a 2010 Tahoe with afm 5.3. 230,000 miles. Never been apart. Runs like a clock. So, even though cyl deac is a weak spot, they can go the distance.   BUT, these engines had the oil changed regularly, AND had 5w30 as spec. I wonder if they would have lasted this far on 0w20? I`ll bet not.
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
    • get a good code reader, and find out what problems the truck has noticed by reading codes. cheap ones can only get basic engine codes, you may want to get one that can get codes from all the computers in your truck.
    • This is sort of my point, salvage yards aren't overflowing with all these 'poorly' maintained trucks - excellent/good/servicable condition otherwise, salvaged only as a result of a bad engine from poor oil change regiment.    In my area, there are no 2007 to newer gm trucks/suvs in any salvage yards. A few are in the 'recyclers' with very obvious reasons for being there - wrecked.
