Hello!  I have a 2017 GMC Sierra. My touch is going black then shutting completely off. When I first get in the truck everything comes on normal, I can hear the radio and change the channel and volume, the screen goes off and comes back on and after 10 minutes it completely shuts off and does not come back on. I can turn the truck off and turn it back on and it comes back on and does the samething every time. I have check all connections on the HMI box, pulled the fuse, disconnected the battery and nothing has fixed it. Any other ideas??
Welcome to the site.
The touch screen is nothing more than a monitor, much like you desktop computer. If it were bad I think it would be black all of the time, thinking your HMI is failing.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
