I ordered a 2021 trail boss 4WD 6.2. Im going to level it with a ready lift that includes the control arms 1 ton ball joints etc...Has anyone used this leveling kit and would I be able to fit with (out rubbing) 20x12 -44 offset with 33 12.50R20LT?
I have a 2020 RST Duramax with the Trail Boss Lift and the ReadyLift level kit...runs smooth! Im not sure about your tire question but it definitely runs smooth and no strain to front end components...
Here is the issue - you start with 2" of OEM lift - you add 2" level kit with RL SST kit.  It is a nice kit - had it on my 2019 GMC AT4 Carbon Pro.  They have a note in there than you "should not use auto 4wd" with the level - issue is the angle of the CV axels is pretty extreme and they had some customers with issues with auto 4wd shifting in and out at various speeds and putting heavy load on front diff due to angles of axels and cv's.  I ran my 2019 for10k miles with it, had no issues, but never used auto 4wd.   Not ideal, but as good as any other level.  When you call knowledgeable offroad shops it is common knowledge (to them) that anything over 4" of lift really needs a drop bracket for the front diff.  So level kits on AT4 and Trial Boss are at that edge.
I swapped my 2019 for a 2020 with trailer tow mirrors and better camera tech for trailering.  I decided to do it right and went with BDS lift kit, which lowers the front diff - so the axels are dead level.    I posted some photos below so you can see the difference in angles for yourself.  BDS and Zone (who is owned by BDS, but their lower cost brand) offer a 2.5" lift kit for AT4/Trail Boss (so 4.5" of total lift) that lowers the front diff without coilover shocks - other do as well- it is more expensive way to go than RL( RL SST kit can be purchased from Tire Rack for $507 - Zone lift kit no shocks is $1,313), but install is a about the same, but given the better axel angles and no issues with auto 4wd this may be the best way to go.  I was able to step up the adjustable coilovers and it was expensive, but well worth the dollars - works great on and off road.
link:   https://zoneoffroad.com/search?fitment=1
Link: https://bds-suspension.com/product?ma=5&mo=1&ty=113&yr=2019-2021&kid=754F
Good luck finding good solution for you.  If you do a search there are a number of threads on this topic and lots of photos.
READY LIFT - CV AXEL ANGLES - 2019 AT4 - SST KIT - STOCK 275/65/18 DURATRAC TIRES
2020 GMC AT4 - BDS COIL OVER 2.5" (4.5" OVERALL) LIFT KIT AXEL - DEAD LEVEL
WHEEL QUESTION - DON'T KNOW ABOUT 20'S BUT FOR REF - THIS IS 275/65/18 ON METHOD NV 18X9  W 18MM OFFSET - ONLY ABOUT 5/8'S OF AN INCH CLEARANCE TO UCA
Edited by Supercup
    • Yes. You need to check out that thing, and the hub further.
    • Would this be normal or a worn CV Shaft? 51K miles 3.5" lift? Boots are intact and no visible leaks showing. Attached is a the video I took. Thanks     https://youtu.be/ZnW7PPRmjJY?feature=shared
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
