Hey guys, I’ve got a 2014 Silverado crew cab with the short bed and I’m looking to upgrade/trade up to a 2021. I’ve got an undercover flex cover now and was wondering if I can make it work on the new truck. Anybody have any insight?
I put my rev tonneau cover off my 2016 Sierra short bed onto my 2020 and it fits just fine.
Grab a tape measure, visit a dealer lot and measure one -- then you will be able to estimate if your existing cover provides enough coverage.
