this is my latest project, was trying to make the under $50  goal , but i exceeded that. total my cost was roughly $100 ,  this filter was run for only 7 days. the next one will probably go for 5000 miles cut it open and update yall soon.
current filter was cut open and hardly saw much metal debris with only 300 miles on it..
Now i've made a strange discovery. While running the spin on filter in full flow mode off the trans line, i would experience a warm running system, about 180-190 degree F. I can only guess see this must have been restricting the trans fluid flow rate thru ths ACDelco filter to the trans cooler.
should also be noted I dont have a transmission thermostat, that was deleted last year, it always runs at 138-145 degrees F after this mod.
After that test I made a By-pass valve up, with a cross feed to the spin-on adapter, and utilizing a 1/8" port restriction  thru the brass valve, to allow some cooling fluid to bypass the filter and continue thru the radiator back to the transmission.  what I found strange about this set up is the transmission temperature now operates at a solid 122 degree F after installing the by-pass valve.
I drove down the freeway for 35 minutes at 70 mph one way, and it held 122F. on the way back it climb to 128-130 degrees F.  i wonder if the 1/8" restriction is reducing the velocity of the hot trans fluid before it enters the radiator cooler and this is improving thermal transfer of heat from the fluid to the radiator coolant?
Bypass valve was purchased from Frantz Filters years ago.. unfortunatly the Owner sold to a new guy so I'm not sure they still make these. If you PM me i can explain how you can easily make your own on a Drill press out of a block of aluminum or brass.
https://www.frantzfilters.com/
I also added a motion Pro filter magnet inside the spin on, hoping to catch some steel fuzzies with it.
Edited by flyingfool
I like this project. It's on my radar.
I was thinking of putting a "Tee" in the line to the cooler to the filter and back to the pan with a restrictor jet to mimic the AMSOIL BP filter setup. Or perhaps a needle valve at the filter exit to regulate flow instead of replaceable jets.
I find your temp readings interesting. Especially after the bypass modification. Hum.... ? You may have solved a different problem for me. :thumbs:
Did you know there are 238 possible cross references for the PF61? That particular filter and nearly all of it's cross references hasn't a bypass valve.
WIX51214 used on HD models has a bypass of 8-11 psi and is the same physical size and 21 micron nominal 3/4"-16 thread
AC-Delco PF1788 same as the WIX if Delco is a must. These are 7-9 gpm filters. Hi throughput isn't a biggie if a bypass system but might be in a full flow setup. No, I have no idea what these pumps put out.
One SONNAX source puts 6L90E pump rates to the cooler between between 1 and 2.6 GPM at 125 F
https://www.sonnax.com/tech_resources/509-sonnaflow-chart-6l90-2011-truck-with-tow-pack
 Also an interesting read:
https://gm-techlink.com/?p=8289
Edited by Grumpy Bear
Thinking about this I realize why the factory thermostat hasn't a minimum flow bypass. It would be a really small orifice.
apparently 2.6 GPM is too fast for proper cooling of the transmissions fluid.  I must say it's taking me longer to get up to operating temp in this cool California weather (55 degrees). so maybe going full flow in a cold climate is the best route, and use a hydraulic spin on filter with-out the rubber "drain back valve" to cause restricion on the the pumps output fluid when in full flow set up.
after cutting open the can, there was no blow off bypass valve in there, which is fine, I'm not concerned with the bypass valve built into a spin on filter. my fluid is very clean and the filter is not holding any metal sprinkles either in which to cause fluid blockage.  Even the old style Frantz filters never had blow off valves in them, they all use 1/8" restrictors on the entry port. but they also have less back pressure by utilizing a depth style Toilet roll filtration vs our screen filtration..
the pf61e is a bit strange looking filter, not sure what it was designed for, it has a wierd metal baffle cover over the input holes. i couldnt use it in conjunction with the oil magnet because of this. but its built rather well with good quality materials. nothing cheap or flimsy not bad for $3
if fluid flow was detrimental to the service life of the trans, as cited by GM tech advisory selling their special fluid flush treatment machine,, why on earth did GM install the thermostat inline to completly plug off the fluid flow until 190 degrees?
I see you need more accurate information. When the thermostat is closed pump output is 'short circuited" to the return internally in the valve itself. IE pump output is always going somewhere. To the cooler or to the return via the valve internally. Understand?
Listen carefully to what he says about lubricity at 200 F.
yes . makes sense.
i'll have to pull the trans line one day and actually time and measure the flow rate with my entire set up.
Friend put a bypass trans filter on his 2007 Sprinter 3500 Van (MB 5-cyl diesel).  He uses vehicle to custom haul loads all over the USA, he and his partner drive about 10,000 miles a month.   Within 6 months the trans went suddenly when he was on the road our west somewhere. Found a used trans and the installed it out there somewhere.   Again a few months later and this trans failed, engine started racing and trans slipping..  So in the first year with a bypass he lost 2 transmissions.  He's been hauling for over 25 yrs all over the US and it capable of doing most any repairs.  He's convinced the trans problems are related to the bypass oil filter he hoped would make the trans last 500,000 miles.  He has put another trans in and has not hooked the bypass filter in and its been a year and no more problems.  He found a spare just in case.
I told him I thought it was a bad idea but when he's on the road he comes with these hair-brained ideas and you can't talk him out of it.
If he's hairbrained,  then it could be operator error and poorly installed , so many variables to the story. i need to see his set up, and read the install directions for his kit. not to say your wrong. but with aftermarket performance parts and general public, they are almost always installed improperly 70% of the time.
the transmission pump is already is bypassing fluid to the radiator on our trucks. I'm taking away 10-15% to clean to a higher level.  hence the reason for my bypass valve to the spin on filter. so i'm still flowing 75-80% thru the stock system .
Now if you take into account the stock design everyone on here with the 6 speeds all have. the thermostats are completely blocking the cooling line system until you reach 190 degrees at the tranny. so there is no oil flow on your factory oem design,  and yet no oil starvation with the factory blockage, the pump in the trans is by-passing fluid for cooling, its not a full flow pump to the cooler
I've been running that Derale kit for 2 years, with the thermostat deleted for over 2 years now, with no issues. I change the spin on filter every other oil change, so 10,000 miles. I also welded a bung and plug onto the transmission pan for easier fluid changes. Will be doing the 60,000 mile fluid change pretty soon.
that's awsome man!  out of curiosity, what filter do you use, and what is your trans temp when out on the highway?
i thought about Grumpy's idea of installing and adjustable valve inline of the trans cooler. I am amaized at how adding 1/8" restriction has Improved my trans cooling.  need to find a quality built valve to give me 3 accurate measured openings points, for when the weather is cold, hot, or towing heavy trailer cross country and i need full flow opened line
I was running a Wix version of the FL1A. Now since I have so much crap under the hood with the supercharger coolant bottle and pump, the vacuum canister, both oil catch cans, I have the trans filter mounted on the cross brace near the brake booster so I run the Wix 51516. I just throw a zip lock bag under/on it and unscrew it when its time to change. Prefill a new one and let her rip...
Keep in mind, I'm not running a bypass like you are, just in series. I tapped (cut and flared the ends) into the line when it comes out of the radiator, and before the cooler built into the condenser. That way the fluid is a little warmer before filtering. I don't know if that's good or bad, but it works for me.
Edited by imiller1974
i highly recommend you convert to a bypass valve just for safety sake
    Aries68
    Aries68
  • Who's Online   1 Member, 0 Anonymous, 193 Guests (See full list)
