I just got my new truck and the dealer is leveling it to keep my warranty. I did a bunch of research and there’s a few out there that won’t work with the 3.0 apparently. They’re using readylift and mine will be the first they’ve done. Anyone have issues? Heard the CV shaft and shock can touch with the wrong kit. If you have what size tire are you running?
23 minutes ago, Tulkas said:
Leveling is a new term to me in this context, can you explain?  Thanks.
Most trucks have a lower front end or a “rake” and a leveling kit raises the front end to make the truck level or closer to level depending the size you get. 2” is the most common I’d say. I did find the answer to my question because the bottom strut style leveling kits don’t work with the diesel. Rough Country makes one for the diesel so going with that. It’s to get it level and help fit bigger tires without a full lift. I can’t do a lift or I void my lifetime powertrain warranty.
What truck and trim did you get with the 3.0?  The GM (trailboss/at 4) should be fine as you can get the AT4 with the 3.0.
I got it figured out. Rough county makes a kit that works apparently that’s either new or somehow looked over it and the dealer also couldn’t find it originally. It’s the RST trim package.
I just bought a 2021 Silverado LT yesterday; the 5.3. Looking into leveling it also. Do you know if the kit you found also works for 5.3 by chance? Or can you can you share the part no./kit no.?
It might but I’d just google a leveling kit. There’s a ton out there. The issue is the diesel motor with 99% of the kits. Some come with shocks and there’s different styles so I’d research it yourself.
I went with the Zone off-road 3.5” kit. It’s a bit more than a “leveling kit,” but I haven’t had any issues with it in about 3k miles.
2020 Sierra 4wd 3.0 Duramax.
The dealer had a ready lift kit in mine when I bought it, it was ok.  I have switched to Bilstein shocks all around and removed the level kit, since you can adjust the front up to 2.5".  Way better ride and handling with this setup
There's pretty much nothing different in the 3.0 vs any other sierra when it comes to lifting outside of the fuel lines needing a small drop bracket to clear the driveshaft if you go 6+ inches of lift.
12 hours ago, Cpl_Punishment said:
What's different about the front end on diesel trucks that make them difficult to level?
There's pretty much nothing different when it comes to doing a lift kit on a 3.0 Diesel vs any other engine other than the fuel lines needing a small drop bracket to clear the driveshaft if you go 6 or more inches of lift.
Makes sense to me but I don't understand why this thread exists, then.
I was wondering that myself, so I figured I'd drop off some knowledge here before some misinformation starts flying around lol
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 2,066 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
