I have a '18 Silverado 1500 z71 8 speed transmission. I cant seem to find the part number for the trans fluid filter. I see one on Amazon that says it fits but in the description it says "for 6 speed trans." Does this make a difference? I also noticed AC Delco makes a synthetic trans fluid (Dexron v1). Any thoughts on if this is better for a truck with 90k than just reg dexron?
I assume 1500 Denali and HighCountry are the only ones with 8-speed transmission.
Vehicle: 2018 Chevrolet Silverado 1500 5.3L V8 FLEX VIN:C
AC Delco Auto Trans Filter Kit
Part Number:  TF922
Product Notes:
All; FILTER REPLACEMENT NOT Reqd WHEN FOLLOWING TSB"S: TSB 16-NA-175 OR 18-NA-177; VIN: C, Auto Trans, Eng Code: L83, 8L90, 8 Speed Trans, Transmission*; VIN: R, Auto Trans, Eng Code: L8B, 8L90, 8 Speed Trans, Transmission*
Per Vehicle: 1; Years: 2017-2018
Part Number:  TF922
Product Notes:
Per Vehicle: 1; Years: 2016-2018
Be careful buying GM parts from other sources as they may not be correct parts.  Go to a local dealer with your vin to get the correct part.
Edited by elcamino
TF922 is the part number you need for the 8 speed transmission.  Amazon has it here:
https://www.amazon.com/ACDelco-TF922-Professional-Automatic-Transmission/dp/B010GPPRQ0/ref=sr_1_1?dchild=1&keywords=TF922&qid=1605879158&sr=8-1
Unfortunately Amazon's parts checker leaves a lot to be desired.  If you put in a 2018 Chevy Silverado 1500, it tells you this part won't fit your truck even though it does.  I've seen that with a lot of parts on Amazon, so always verify that the part you need is correct.  Rock Auto has always been a good cross reference for parts or you can always use Advance Auto, Autozone, Oreilly, or NAPA.
No need to waste money buying parts from a dealer if you know how to verify the part numbers unless you really enjoy paying the excessive dealer markup.
The fluid it takes is dexron HP  not dexron VI.  Using a full synthetic is best for any transmission considering the abuse they take and not getting serviced like they should.  You can use AMSOIL's ATL fluid.  If interested send me a PM with your address and I can get you a quote.
DO NOT use Dexron VI.
8 Speeds use Mobil 1 LV HP ATF Synthetic with the BLUE LABEL.
You will also need to follow the specific fill and level check procedures for the 8 speed as well as it has no dipstick/dipstick tube.
Edited by newdude
I had a feeling the dextron VI wouldnt work. Thanks for the headsup
I cant find Dextron HP. It says it is a discontinued product. Trash Amazon tells me VI is compatible with my truck and other stuff isnt that actually is. I should've known better lol.
No, I have the Z71 that i think is one class lower.
Which ATF from amsoil- the OE multi-vehicle? I use amsoil engine oil in my truck. Hear nothing but good things about them
Any idea how much fluid I'll need to buy,  or where to find that info? I am reading some pretty conflicting amounts over a wide range from 8 quarts to 14.
You can use the OE OTL or the Signature Series ATL fluid and you can look up the quantities here.
Basically if  you are just doing a pan drop then 9qts will cover it with a little extra, if you do an exchange then depending on what transmission you have it could be 16qts or more.  PM  me with more information and I can help with this.
Are you 100% that you have an 8 speed then?  What trim level is your truck?
Z71 isn't a trim level, its a suspension package option.  You need to verify what transmission you have in your truck as there is a big difference between the 6 speed and the 8 speed autos.  They use different filters and fluids.  If you really do have the 8 speed then you should be using the new Mobil 1 HP LV fluid with the new blue label.  This is the fluid that replaced the older fluid due to issue with shifting and TCC lockup in the 8 speeds.
https://www.amazon.com/Mobil-124715-Synthetic-Quart-Bottles/dp/B07Q3H159N
Otherwise, if you have the 6 speed you can just use regular Dexron VI.
On 2014-2018 Chevy trucks, Z71 was "technically" a trim level on LT and LTZ.  You couldn't just get Z71 suspension option on an LT trim.  1LT was the regular 4x4, 2LT is a LT Z71.  Same for LTZ.  1LT/1LTZ is chrome bumpers and regular 4x4, 2LT/2LZ is Z71, body colored bumpers, Z71 instrument cluster.
GMC on the other hand, Z71 was just a mechanical option 2014-2018.
So if OP has an LT Z71, he has a 6 speed.  If he has an LTZ Z71, it could go either way 6 or 8 speed depending on engine option.
Edited by newdude
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 395 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
