This killmat is some good stuff. Been doing a big audio upgrade to my 18 Silverado. So far got the matting, two front door speakers, high output alternator, and the big 3 installed. Still got the amps, 2 rear doors,2 dash tweets, sub, and wiring everything. Fun-Fun-Fun!4975afa58d96a71852695ef197538b45.jpg
Sent from my SM-G970U using Tapatalk
5dc860afab3375c51bc9be515b746b38.jpg6bd84647989de442030f29ab9960f919.jpg91157a15a78efb14dd1c37b377056ac2.jpg4be5548bce2e5c7d3d07042ba7a4459e.jpg
Nice! Whats the plan for the sub and pro audio speakers?
I built an underseat ported box for my sub. The pro audio speakers go in the doors. Doing that install today. Will post pics soon. Also doing a rear seat lift. Fabricating my own brackets.
Sweet! Interested in seeing what that sub box looks like. I put memphis pro audios in the rear and infinity compnent 6-1/2 90w in the front. Figured I'd keep the front to where it has some bass for the wife since she doesn't like subs anymore lol. That system your building should sound real good.
Does this KILLMATT replace the carpet padding and if not is it thin enough not to cause carpeting fit issues? Be gentle, I'm ignorant of such things. ?
Does this KILLMATT replace the carpet padding and if not is it thin enough not to cause carpeting fit issues? Be gentle, I'm ignorant of such things. [emoji6]
No doesnt replace carpet padding. Is thin enough to go underneath no issues. Its butyl rubber
Picture of my sub box. Tuned to 36hz. This was done using box calculator on the12v website19b4c4e5b54e4e6542ed61f9b1bce637.jpg
Got to hear it for the 1st time today. Oh my god does it sound good. I still have to tune it. But that box slams. Pro audio speakers sound so good.
Have to put everything back now. Was fun to finally take my truck apart and put back together. [emoji3]
Very nice - Any chance you’re in Illinois? I’m looking to do a similar build and would like to bounce some ideas off you. Thanks
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
