I’ve got a 2011 Silverado with 148k miles, just recently the traction control light and brake light will appear on the dash, shortly after the brake light will go off, and continues to come back on here and there while driving. Both light also only seem to come on when it’s cold outside. Took it to a place to get the codes as no codes popped up. Anyone run into anything like this? Thanks
The scanner needs to read c and u codes,cheapos won't do it,you more than likely have a bad connection at a wheel sensor
I was also thinking a wheel speed sensor. How cold is cold enough to cause the issue?
Mine did that for a while and then got worse. Cruise would not work, rear brake lights would flash and cycle on and off and transmission interlock would not let me start in park. Turned out to be the Brake light switch at the top of the pedal. Replaced the switch two years ago and no problems since.
Also check your brake fluid level.  The master cylinders have been known to have a seal leak that will suck brake fluid from the booster into the intake manifold.  If the brake fluid level gets below half, it will throw a code and show those warning messages, but the vehicle will stop fine.  If the level is borderline to trip the sensor, it will do it on cold mornings.
Edited by MaverickZ71
You probably got this fixed by now but as somebody said change the brake switch. Mine had the exact same problem only in cold weather. Switch fixed it.
  • 3 years later...
  • 3 weeks later...
If you have a scanner that can read GM diagnostic codes (some Actron scanners do) you'll get more specific info on the issue. I had the same problem and the GM code pointed to a faulty 4wd selector switch on the dash. The terminals on the back of the switch become corroded and send incorrect ohm readings to the 4wd shift module. When the drive setting doesn't match the signal, you get a service stabilitrak error on the dash.
The selector switches are inexpensive and easy to change out.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 423 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
