I have a 2020 GMC 2500 Denali with a bank’s derringer and idash and my app works with no problems as far as starting and unlocking. The truck status part of the app doesn’t work but the other is no problem.
Edited by dasbill
Posted in wrong thread
well i have had mine loaded enough times to realize these shocks are about same as the 1500s....super mushy with no rebound dampening whatsoever....when its empty the springs give it a firm feel but load springs up with weight and i can feel how mushy the shocks are.....2500 loaded feels identical to my 19 RST.......so these babys are going buh bye
i have about 600lbs in bed which makes it feel like a stock 1500......also have had close to 3k in payload just other day and few more runs of 1500-2500 lbs in bed.....my brother just put bilsteins on his new 2019 and loves them.....he is fairly mechanically inclined and knows more than avg joe about suspension and how it works, etc.....will be my next thing to do
On 12/6/2020 at 9:05 PM, gSwift said:
Do you ever use the app to unlock doors or start your truck? I do, pretty regularly, and i've read that with the Derringer plugged into the OBD port, you can no longer use those features or get any monthly OnStar reports.
I have the Derringer and use the app all the time. No issues at all. The monthly OnStar reports are a bit useless though, 1/2 the data comes back as not able to read. tire pressure, oil life and stuff come through though.
Thats awesome to know! Yeah I don't care about the OnStar report as long as the app features still work.
FYI to all, just spoke with Fox and 4 wheel parts, where I ordered from. Fox said some applications are 12-16 weeks others 16-20 weeks out. 4 wheel parts said Fox told them they have the P.O. from them and it looks like then end of January they will ship to their wear house to then ship to me. So maybe by Valentine’s Day...
Yeah it took a little over 3 months to get mine. I don't have that kind of patience, so needless to say I was extremely aggravated. lol
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
