Hey guys, Got a 2019 Z71, bought new with 12K miles on it.
Ever since new, it sounds like the front drivers wheel when hitting a bump at lower speed(around 15-30 mph) is almost bouncing, like a bad strut/shock/bushing. Had it checked thoroughly by dealer twice, everything seems tight. Had an alignment done too.
Seems also to be noticeable at winter time(40 degrees or colder). Didnt notice much this summer, also dont notice at all at highway speeds.
Anyone experience this or have a thought? Dealer is willing to replace strut but that doesn't seem to make sense either. I have even watched it out the window, and tire shows no sign of bouncing.
I have a similar noise going through a dip when the truck is coming back up. Sounds like a knock/bump and can actually be felt in the floorboard.
I can hear it if I bounce the truck on that side too.
I’m gonna try to take it in this week.
That exactly it! seen nothing wrong and my buddy is a 20 year certified gm tech, he is who works on these and my personal truck, and even he is stumped. ALso hard to duplicate problem
Let me know what you find if anything.
Tell them to pull down on the fender to bounce that corner. I can replicate it fairly easily once the truck starts moving enough.
Had the same issue a while back. Easies way to replicate it is drive over a piece of lumber 4x4 or sometimes 2x4.
And yes my dealer gave up on it so did I but in a stroke of luck its gone. I think what ever was the issue it rattled its way out and fill of the pickup for good. Either way can't hear it anymore
What did you find out? what do you mean by pull down on the fender, are you saying the fender is loose or hitting while hitting a bump?
Haven’t had a chance to take it in yet. Maybe this week?
No I mean to pull the whole truck down to bounce the suspension. Pop the hood, put 2 hands on the fender (from the side you’re hearing the noise) and pull down repeatedly to bounce it. (Seeing as how everything is plastic on the front bumper I felt this was the easiest/safest way)
When I say “pull down” I mean with your whole body weight. Get that sucker moving!
Okay i will try that. IS what you were hearing considered normal just bouncing or noise feeding thru the fenders? Or did you find something wrong?
 I had a similar noise from the front passenger side, and would hear it when going over bumps, railroads, etc.    The sound started around 15,000 miles and I just tried to ignore it for the next 5,000 miles, but luckily it disappeared completely when I upgraded the shocks.
Definitely not normal. Based on my unscientific “put your finger on the part to feel the noise” experiment it’s coming from the shock. I’m guessing inside.
The left side is silent.
I tried bouncing it, might not be moving it enough as i am not the biggest guy, but it sounded fine. However, another mentioned drive slowly over 2x4 and that duplicates it. Passsenger side is silent
Curious, do you guys have z71 suspension with same white ranchero shocks, wonder if some are bad. Sounds like it isnt acting properly at low speed, probably a internal valve issue.
My tech said bring it in, we are going to try shock and see if it improves/or stays the same. Either way, it is one more thing out of the way
PS: i wonder if these damn trucks are too light, With all the plastic and aluminum, i notice the sound is bettter when the truck has cab full and it is warm outside
Tried this, it does make the sound. THose horizontal cracks in pavement do it too.
How many miles did you notice it took to go away? I only have 12k on it, might need to break in more, shocks could just be darn stiff
Alkaspeltzer,
I HIGHLY doubt it will go away since its most likely a blown shock.  I've had to replace many over the years on various vehicles for various issues similar to what you describe.  I just replaced my white Ranchos in my 2020 Z71 for the very same thing and when I pulled out my passenger side shock I readily identified a small leak that appeared to have been present for a while.  Is it normal for a shock to wear out, yes, is it normal at that low of mileage, no, but it does happen and with a prior owner who knows what he put the truck through.
Mine started clunking and making weird noises pretty bad around 15k miles, but it would occasionally clunk long before that, my guess would be around the 10-12k mark.
If the dealership is willing to replace the shock, let them, that seems the obvious route to me.  If that doesn't solve the problem them its something bigger and the dealer needs to address it under warranty anyways.  Regardless, step one would be to replace the shock and if they are willing to do it, let them.
Also, with a deteriorating shock, there is a good likelihood you wont see wheel bounce.  Most of the sound is coming from internal components as a result of damaged components or loss of dampening fluid.
Either way its a minor thing, don't worry, it will all get resolved shortly.  Good Luck!
Edited by Gangly
About 20k miles or so
Just wanted to give an update. I did get the dealer to agree to shock replacement.
Clearly it was blow. When we removed, it was not as smooth as the other side and had little resistance. We actaully knowing it was failed pushed it back past the seal, and it barely had any pressure. In fact, all the oil was mixed with air/water where with the nitrogen charge, that shouldnt happen as much.
Been a couple weeks. Definitely quiet and rides like a z71. Took the bounce and lightness i was feeling out of the truck. Love this thing now.
Thank for all the support!
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 209 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
