Well got a new tail light from Frankie. Great to deal with.
However, that didn’t help with my hyper flash.
Anyone have any thoughts?
Thanks
Hey everyone. I am still having an issue with Hyper Flash with my 2016 Denali. It comes stock with LEDs. I didn’t change bulbs or anything. Something happened one day about 6 months ago. Just happened. I am hoping someone might be able to help. Dealer here is saying a new board. That is $1000 plus Installation. Help! TIA
Sorry to hear the problem is still present.
Could you be more detailed in the term "board"? Do you have a work order quote from them with the actual description of the "board"? Might help some help you.
Actually I don’t. While at the dealer, the mechanic told me this is what he thought was the solution. Also the price for the board was about 1k.
I didn’t want to spend that without knowing for sure.
Thanks
Thanks
If they can not even provide the actual name of the part, I would personally find another lot who is not just trying to take advantage of you.
Ask for details, where is it located, what does it control, is it covered under any warranties, can they show you where it is, so you can take a picture?
Just for the hell of it I would try slicing in a 50w 6 ohm load resistor. This is what you do for trucks that come with incandescent taillights rather than LED. LED take way less power to light. So you need to trick the computer into thinking the led taillights are taking just as much power. Sounds like your computer is misreading the power running through the light. You can buy a 2 pack on Amazon for $20
So now my dome lights stay on. My signal light still hyper flashes.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
