I’ve learned that the 15x10 inch rims do not look good on newer style trucks like it did on the old square bodies. What size rim and tire on a stock truck of this generation do you run?
Best tire/rim size is completely subjective and comes down to the wants of the owner.
Someone with stock height is going to want stock sized tires. Lowered and lifted trucks can change that size.
265/65/18's are the factory sized tire and so were 275/55/20's.  Going much bigger than a 32-33in tire will cause rubbing on stock ride height. I've run both of those size tires on previous trucks.
Edited by CamGTP
For what it's worth I changed my factory 17" SLE rims and tires for a 20" set of factory Denali rims and tires because I liked the look of them better, but they ride like crap. The Denali suspension is different than mine.
Will the 275/55/20 on 20x10 rims cause any rubbing on a stock truck? I’m trying to get that old school look where the tire sticks outside from the body a bit and is wide enough to look like some type of racing slick from behind if that makes sense. Thank you!
Factory sizes were P265/70R-17, P265/65R-18, and P275/55R-20.  The 17 inch factory wheels were 7.5 inches wide, the 18 inchers were 8 inches wide, and the 20 inchers were 9 inches wide.  If you stay with those factory sizes and wheel offsets (available online), you won't have any rubbing.  The 17 inch tires are generally less expensive, have more brands available in that size, ride softer, and offer better flotation for off-road use.  The 18's and 20's generally handle better, ride rougher, cost more, and have less brands available as you go bigger.  You have to have at least 17 inch wheels to clear the factory disc brakes up front.  If you ever use tire chains you'll want to go with the 17 inchers.
Edited by MaverickZ71
    • same here , i have a 2020 first gen and the cost to repair these engines far excedes replacement
    • But Grumpy I did show several subdivisions that had homes starting in the 170K range. If you bought a Townhouse or Condo you could go cheaper. Same with a car 3000 dollars in the 70s translates to around 20K today. There are several models at that price. You actually get more for the money. In the 70s I drove a 3000$ car bought a 28K home and made 4.50 per hour. Thank goodness for overtime. Today I could buy a 170K house drive a 20K car and make 25 dollars an hour operating the same machine today. The difference the house, car, machine would be better and have AC. And I wouldn’t be taxed on overtime. And statistically your wife works too. Easing the burden. I thought we agreed to disagree. I brought receipts earlier, showing examples. I think you’re more stubborn than me. I was done with this debate.
    • I’m definitely interested to hear the end result here.
    • My 2025 Silverado 1500 had to receive a brand-new engine (long block) under warranty last month at only around 16,500 miles. Before the replacement, the truck repeatedly displayed "Engine Oil Level Low" warnings, even though the Oil Life Monitor still showed around 50% remaining after about 6,000 miles since my last oil change. After seeing the warning several times, I checked the dipstick with the engine cold, and the oil level was completely normal. The next day, the message escalated to "Add Engine Oil." At first, I assumed it was just a faulty oil level sensor, so I brought the truck to the dealership. After inspecting the engine, they found internal cylinder wall scoring and ultimately replaced the entire long block under warranty. Before this happened, I was planning to install a 4-inch lift and suspension upgrade on my truck. After needing a new engine at just 16,500 miles, I honestly don't see the point anymore. I also contacted GM to ask whether my vehicle qualified for a buyback, but I was informed that it does not at this time. Anyway, this experience has left me with serious concerns about the long-term reliability of this engine. I sincerely hope NHTSA expands the current investigation or recall to include 2025 model and performs a thorough inspection of affected vehicles. My biggest concern is that these engines may fail shortly after the powertrain warranty expires. If GM truly stands behind this engine, then at the very least, please consider extending the powertrain warranty to 10 years for affected owners. That would go a long way toward restoring customer confidence.
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
