I purchased a Sierra hd Denali that came factory with standard mirrors and I want to convert to tow mirrors. With all of the factory power fold, power adjust and puddle lights already being there, is there an aftermarket option that is ready to go? What mirrors are must having luck with? I will also be upgrading the factory nav to CarPlay but first things first.
All depends on the build date of your 2015.  Check the driver's door jamb for the silver label with your VIN on it.  You should see a date in MM/YY format.  This is important for having all of the lighting work.
Either route you will need new door harnesses or modify your existing ones.
You can go the OE route on the mirrors but you are looking at $1100-1400 for just the mirrors.
You can get full feature from Boost Auto Parts 2015 - 2019 New Style GM Tow Mirrors – Boost Auto Parts
With either of them you will lose the puddle lamps (the ones that point down on the ground) as the tow mirrors didn't have them 2015-2019.
No mirror will be PnP. You’ll need to modify your door or swap them out. I validate each customer truck and mirror prior to provisioning a solution. You can reach me at HarnessDR.com
Thanks for the info guys. Once I make my mirror choice, I will be in touch. I'll also update with photos here.
I have a brand new set of OEM factory take off tow mirrors from my 2016 2500HD Denali with the factory wiring harness. They were taken off my truck when new in order to install the standard mirrors. Using the factory wiring harness, they were a direct swap on my 2016. You might verify that there were no changes to the mirror harness between the 15-16 model years, but please reach out if interested. They have been boxed up in storage since new.
knegangard, I have an aftermarket set picked out but I am definitely interested in yours since I have not made a purchase. I was going to shoot you a DM but it will not let me do so, but let me know what you would want and your location and/or shipping.
I sent you a message, thank you.
Well I got lucky and the seller found a set of factory mirrors and all of the OE harnesses that he had purchased to do the install and never got around to it. I ended up getting a good price on everything and will soon be doing the install. Once done I’ll have a set of DL3 mirrors and the factory door harnesses for sale.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
