So,this is my son's Trailblazer....it went into reduced engine power one day on his way home from work and barely made it to my house.Plugged in my scanner and came up with P1512,P1515 & P1516.A friend of ours,after checking out You Tube installed a new throttle body,no change.It still has an erratic idle...goes up and down from 500rpm to about 2000rpm.Re-installed the old one and returned the new one.For some reason it got better and now only has a P1512 code.Did a idle relearn procedure but not sure if I did it right,no change.Both O2s acting funny so replaced them,no change.Tugged on the wires at the connector,no change.They seem fine.One odd thing though,the actual throttle position is at 22 and the throttle position desire changes as it should.Also when stepping on the gas pedal shouldn't the throttle blade move accordingly? It is fixed closed.
Any Ideas? I'm thinking of getting another throttle body.
Posted here because I saw nowhere else to post it.
Well,got her running pretty good now,hopefully it will last.
Removed the #3 connector to the PCM and tested all the wires from the throttle body connector to check continuity....all were good.Noticed a split on a vacuum connector coming from the air box down to a fitting on the engine,replaced that.Went to AlldataDIY(been a member for years) and found that vacuum tube went to the fuel pressure regulator.Not sure if it had any bearing on the problem.I put it all back together and bingo!! The main dtc was p1512,correalation between the requested throttle body % and the actual %.So my son's pretty happy he has his car back :)
13 hours ago, txab said:
Good to see you around Gary. Glad you figured out your issue.  :thumbs:
Thanks bud,i don't often post but i do browse the site occassionaly.
I bought an Autel MaxiPro808 scanner which helped a lot.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
