to me, it sounds like these new engines do a smidge better on gas and that may be enough to bring over some 6.0 owners or convince someone who was considering a new 1500 to go with a new gas HD.
Well I was getting about 7 MPG with my 6.0 towing the 5th wheel and from the reports people are getting 8 to 9. so if I gain 1.5 mpg on a 36 gal tank, that gets me better than 50 miles of extra range. I will take that any day. My 3500 is on order so we will see.
So I have a '21 2500 SLT CCSB.  Just over 1k miles and looking at "trip 2", which was reset when I took delivery at 21 miles, it's showing 13.4 mpg.  This is a mix of highway and grocery getting over those thousand miles.
My best 50 mile average is 16.9, which was mostly highway, and well behaved city.
If I look at the 20 mile average when driving around town, and launching at green lights like someone else is buying the gas,  it's about 12.3.
Haven't towed yet.
Bottom line, in mixed use it's about the same as my '00 1500 SLE 5.3 ECSB.  Maybe 1mpg less.
If I need to just run an errand in town, I take the '00. The 6.6 gas 2500 does not like stopping and going. If it can stay rolling it's in the 16-18 range unloaded.  Cruising on flat highway at 75mph I'm seeing about 18 instantaneous mpg.
How you drive it has a huge affect.   Soft on the pedal vs hammer down makes a big difference.
    • This video may not be the exact content for the joke thread but its a lot of laughs so here it is, I've only watched a portion of it so far but if anyone is looking for some light hearted good soap box driving action, its here. As a note in the upper left of the screen it shows the number out of 100 to refer back to any particular vehicle for comment !.    https://www.facebook.com/reel/1351928276956715
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
