Hi All,
I've got a 2017 GMC 1500 Denali, 5.3L, that's got a 2" RC level kit  with 285/55r20 on stock chrome 20" Denali wheels.  Looking to upgrade & put a true lift on it.  But I'm torn on which way to go.  Here are the three options I'm considering...
  1. 4" Fabtech Uniball Magride and 305/55r20s - At first I thought for sure this would be the way I'd like to go.  Nice mild lift with 33" tires that shouldn't really have much of any performance issues for the truck.  This 4" lift is one of if not the only Magride compatible lift at this level. The problem is that the 305/55r20's are actually only about 3/4" taller than my current set up.  Fabtech's website states that this lift would fit up to a 295/55r20 tire which kind of surprises me & is maybe 1/2" more tire than my current 285's.   Some pics I've found show some trucks looking just like I'd like, some even running 35's, but others looking like there's almost no change to the truck's stance.
  2.  6" Fabtech Gen 2 Magride & 35x12.50r20s - Saw a truck this weekend with a sim set up & it looks just about right to what I'd like my truck to look like.  This Fabtech lift also doesn't offset the front like many other lifts which may be a plus.  Don't know how well this would work with stock 20" wheels.
  3. 6" BDS Denali lift with 35x12.50r20's -  Seems to be a very popular lift.  Little more expensive than the 6" Fabtech but not terribly so.  Does offset front end a bit & requires 2" spacers for the rear to match if i'm not mistaken.
So, with all that said, what'd you choose & why?  Any pics of these set ups would be helpful, especially from those with the 4" Fabtech lift.
If you're going to lift it , lift it. Go as big as you can afford.
Ditch the factory wheels too.
A lot of guys dipping their toes in the lifted truck water always want to keep their factory wheels. I did at one time too then I realized the offset looks dumb IMO.
Go here and look at hundreds of trucks like yours with 6" lifts and 35's
www.customwheeloffset.com
Go to the gallery and enter your truck and see what lift, wheels, tires look like
Sent from my Pixel 3 using Tapatalk
Thanks Dieselfan1.  I do like the look of a 6" lift & 35's.  Can find a million pics of that setup too.  Harder to find good pics of the Fabtech 4" Denali lift though.  Seen a few with Fabtech's 4.5" knuckle lift & some of those with 35's as well.  Haven't seen any with the 4" denali/magride compatible thought.
The one hesitation I have with a 6" lift & 35's is the expense.  They tend to be a little have more expensive tires, less gas mileage, more wear, etc.
What's your budget for everything?
If you're not ready to drop at least $6000+ just for the lift, wheels and tires, and another $1200-1500 to install it, and a bunch of other stuff you'll want after you lift it, put a level kit on it and new tires call it a day.
Don't be so afraid to spend money and roll like me and my pal Frankie.
Oh and let's not forget my Bro covetedstyle[emoji857][emoji857][emoji857]
BTW I went shopping for you....
https://www.customwheeloffset.com/cart
3d5963c591edff64740994b7dca9aba5.jpgda0bad4e5022db78ab7c980eff1d3d97.jpga97649c35f3e18c091f45423ca539180.jpg
BTW we roll McGaughys 9"
LOL!  $6000 + $1500 for install wasn't exactly within my budget.  More like $3500 for lift & tires is more like it for me.  Staying with the stock wheels for now.  That can be changed later on if I change my mind on the look & save me some cash for exhaust that I'll need next.  Labor cost will be only for the alignment once installed as I'll do the actual lift myself.
Nice truck you got though...
So not a Denali, but I have 3.5 of lift and 34s, on stock wheels, will give you an idea of the 4" lift size. I am right at 2k for tires, lift, and alignment.
Nice clean looking setup.  Any rubbing or trimming required to fit those?
Thanks, I like it alot. I am running 1.5" wheel spacers, so I had to trim the back side of the fender. Could have eliminated the rub with zip ties probably, but I wanted plenty of clearance so I did the norcal mod, I have over 1 inch on all sides, all steering positions now. And the factory plastic covers all signs of trimming.
Tires are 295/60R20 Falken Wildpeak AT3W
Here's a pic next to a stock chevy
I installed the fabtech gen 2 a couple months ago and have no issues at all with it.  I picked that lift because of the factory track width.  I wanted to run a 12 wide wheel without sticking out farther then needed.
What size tire do you have, what’s offset of your wheels & did ya have to trim much to make clearance for the tires?
I have 22X12 -44 offset with 35" tires.  I was hoping to only need to do minor trimming but i ended up having to a norcal mod and minor trimming on the front valence.
I'm thinking you pretty much have to norcal mod most of these trucks once you get into negative offsets. Im at a -12. Granted my kit said a 33 on stock offset was recommended tire size up to a 0 offset. Im a 34 on -12 so thats on me.
I have a 2018 Silverado custom. Went with a 4” lift and running 35x12.5R18. Did some minor trimming and everything is good. Love the lift. No rubbing at full turns and articulation off road.
35's with only a 4" lift?  That leaves me with some questions... Which lift did you go with & what are you specs on the tire/wheel package?  Was advertised as a 4" lift or was the the actual amount of lift your got from the kit?
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 445 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
