We all know by now that we have 4 switches, with a 5th pre-wired for a light at the roof. So, the question is being asked, what are you connecting, or tend to connect to those switches? I figured we could do this for fun and to generate ideas for ourselves and others.
I'm currently working to connect the Baja Designs lights sold through GM Accessories.
I'm considering an ARB air compressor that mounts to the truck bed wall, possibly a train air horn (not seriously), and v some sort of electrical connection for power tool battery chargers.
How about you?
Awesome thread idea!  So far I have my footwell lighting (really like having them on a switch!) and backup lights in rear bumper. Saving one switch for a light bar in front grill when I figure out how to integrate one cleanly and not sure about the other 2 yet!
Did you guys have these installed after purchase? My 20 AT4 doesn’t have this but I do want it....
Yes. I installed them myself.
Currently planning on the WAMS Spec BCM Strobe Controls and the Blackout/Stealth mode when the switches arrive :) Past that whatever else we add that requires a physical switch I guess!
Currently planning on the WAMS Spec BCM Strobe Controls and the Blackout/Stealth mode when the switches arrive [emoji4] Past that whatever else we add that requires a physical switch I guess!
Blackout/Stealth mode??? You have my attention.
Yup new features although the more I look at these switches and as awesome as they are probably wont work for something as simple as this (applying a ground). Kills all exterior and interior lighting (IPC dims as much as possible) and the strobes are basically exactly what you think complete with headlamp wig wag (if you choose lol) all with factory hardware :)
Yup new features although the more I look at these switches and as awesome as they are probably wont work for something as simple as this (applying a ground). Kills all exterior and interior lighting (IPC dims as much as possible) and the strobes are basically exactly what you think complete with headlamp wig wag (if you choose lol) all with factory hardware [emoji4]
When I connected the lightbar to the switches I had to connect a ground. It was simple, and here's what I used. Easily accessible. All I had to do was move the fuse box on the dash for a moment. a4cfa92767b6f3044c5bb5f6d3a12296.jpg637b5fd3801fc831d644d3b1b8aaf7f6.jpg
Radar detector.
I would've never considered that for an auxiliary switch. Just curious, why would you connect a radar detector to an auxiliary switch? Not judging.
Sorry I should have explained better I just need a basic switch to pull a terminal (or three) to ground on the BCM these switches are probably big time overkill even though I LOVE the look!
Didn't realize that was a judgeable offense... ?
I don't like wires hanging all over the place, and didn't want to have to reach up to turn it on and off. I turn it on/off frequently if i'm going thru somewhere that sets it off, get stuck by a car with blind spot mirrors, etc.
Didn't realize that was a judgeable offense... [emoji23]
This isn't One Life Fitness. This isn't a judgement free zone, lol. I was just curious and didn't want you to feel like you were going to have to defend yourself.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
