So to start with the truck is a 2014 1500 Z71 with 20" factory wheels and tire size and leveled(2.25" I believe).  I bought it this way and had no real complaints but the ball joints are starting to give signs of needing replacing. I hold on to vehicles for the long haul, last was totaled by another driver or I would have still been in it.  I personally havent had complaints on the ride maybe I was used to my other truck but never had anyone who rode with me complain either 97% of my driving is on paved roads.
The plan is to replace the UCA with either Cognito or Kryptonite(doing this for ease of maintenance), replace the lower ball joint with a moog problem solver for the aluminum arm, and upgrade/replace the struts(still have some life but why not while I am here).
Noting I am torn on the strut/shock upgrade as well but that is not the focus of this post. Seriously considering keeping the spacer that is on it and going with the 4600's since I dont offroad or really drive rough roads but also considering the Bilstein 5100's or possibly the RS9000 quicklift, for my use I am looking to stay around $400 here for the front.
There are tons of threads here on most of these topics, but most are people looking to upgrade wheels or tires.  I am trying to see who on here has upgraded the UCA's and stayed with factory wheels and tires and not had issues.  Cognito says it will work with factory tires and wheels and Kryptonite says they should but will more than likely rub at full tilt.  Does anyone have any experience here or pics to show clearances?  I know these two are close and will give a nod to Kryptonite and probably to that way if I knew how bad the rub is etc...
Edited by rlnthndr
I had a 2" front level and I was running 33x12.5x18s with the stock UCAs and getting the rubbing on the UCA,
Stock wheels.
I had a Motofab UCA installed with a 3" front level (and a 1.5" body lift), the rubbing was almost non-existent - maybe a bit on total full lock.
I, now, have 35x12.5x18s and same - no rubbing except on total full lock.
Still with stock wheels.
YMMV, I suppose?
Yeah Kryptonite stated rub may occur at full tilt as I said in the first post.  I really like their offering but also would prefer the Cognito's claim of no rub with factory wheels and tires.  My assumption is the rub for the Kryptonites are tire and not wheel.
Also made the decision to go with the Eibach Pro-Truck Stage 1 kit for suspension.
I would recommend accutune shocks give them a call the owner is great, honest, and smart. Icon delta joint uca are nice. I own a set of accutune Fox 3.0 DSC shocks and I love them. Much better than my 3.0 adjustable icons where. Dirt kings uca have been good. I am having to rebuild the uniballs after 75,000 miles. But I would of done icon delta joints if they had been out. Make sure you install a set of camber lock out plates. They solved a ton of issues. Clunks and camber coming out of alignment. I bought the dirt king lock outs. I’m happy with them.
So went ahead and ordered the Kryptonite UCA's, Cam bolts, tie rod ends, etc... and the Eibach Pro Truck Stage 1 kit.
I appreciate the responses, but Again it is a budget build and will do more than it will be asked for.  As stated not looking for a high end lift for a level with decent ride on factory wheels and tires.
  • 4 weeks later...
Leaving this here in case it may help anyone.  Some lessons have to be learned the hard way.
So installed everything this weekend and while clearances were close I thought it would be ok, didnt take into account full tilt turn under load.  Needless to say I now have a set of Kryptonite UCA's sitting in the garage with new factory replacements on the truck for now.
What I have learned from a lot of reading and what not after the fact is that most UCA's require a backspace on the wheels of 4.5".  I could have done 1/2" hub/wheel centric spacers I would have a fight with where I got my tires as they will not service a vehicle with spacers on it.  So I will probably buy new tires and wheels next time I have to replace my UCA's  which honestly if like my previous ones may be 80K+ or if I convince myself to do a lift.   May sell them still up in the air.
That said the suspension definitely takes bumps better i.e. speed bumps at speed used to jar the truck now feel pretty smooth, no body roll in cornering that I did have, etc...  after replacing LBJ, UCA, and struts alignment was only off on 2 parameters by an .# degree.  That surprised me.
If you want to keep factory wheels it seems cognito is one of the only ones that was designed with this in mind.  I choose the kryptonite based on feedback from those with lifts greater than 3" still like then and the angles looked good. but just not what I need right now.
Edited by rlnthndr
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   5 Members, 0 Anonymous, 506 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
