I bought a 2009 gmc Sierra with a 5.3 vortex engine with 51000 original miles on it. It has a tapping noise at start up.quiets down after engine warms.Is this normal or do I need to have it looked at?
It's probably one of the hydraulic lifters on one of the AFM cylinders ticking against the cam assembly. Very common problem. Could also be a small leak on your exhaust manifold which seals up after the engine warms up.
Sent from my SM-G892U using Tapatalk
Piston slap is always very common to the LS engine. Once the engine warms up, the pistons expand and the noise slowly goes away.
4 hours ago, Robert Joye said:
So should I worry about it ?
no. I know many people who have this issue and are pushing near 300k.  If you keep up with your truck, and keep an eye on things like Oil pressure, temp etc you should also get many miles out of your motor.
Get a bi-directional scan tool on it and check for misfires and can also function test the  AFM system.  Do the easy stuff first, check the plugs, compression test, check for exhaust leaks, get a mechanic's stethoscope and listen around to pinpoint the noise, etc.  You can even use a screwdriver or extension stuck to your ear and whatever you want to listen to.
Can you isolate which cylinder? If it's an AFM cylinder I'd consider getting a programmer or a range kit to deactivate it before the lifter collapses.
    RichardRS
    RichardRS
  • Who's Online   2 Members, 0 Anonymous, 593 Guests (See full list)
