I bought a 2009 gmc Sierra with a 5.3 vortex engine with 51000 original miles on it. It has a tapping noise at start up.quiets down after engine warms.Is this normal or do I need to have it looked at?
It's probably one of the hydraulic lifters on one of the AFM cylinders ticking against the cam assembly. Very common problem. Could also be a small leak on your exhaust manifold which seals up after the engine warms up.
Sent from my SM-G892U using Tapatalk
Piston slap is always very common to the LS engine. Once the engine warms up, the pistons expand and the noise slowly goes away.
4 hours ago, Robert Joye said:
So should I worry about it ?
no. I know many people who have this issue and are pushing near 300k.  If you keep up with your truck, and keep an eye on things like Oil pressure, temp etc you should also get many miles out of your motor.
Get a bi-directional scan tool on it and check for misfires and can also function test the  AFM system.  Do the easy stuff first, check the plugs, compression test, check for exhaust leaks, get a mechanic's stethoscope and listen around to pinpoint the noise, etc.  You can even use a screwdriver or extension stuck to your ear and whatever you want to listen to.
Can you isolate which cylinder? If it's an AFM cylinder I'd consider getting a programmer or a range kit to deactivate it before the lifter collapses.
    RichardRS
    RichardRS
  • Who's Online   3 Members, 0 Anonymous, 836 Guests (See full list)
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
