It's not that it sits for extended periods. I drive it every couple of weeks. However, I did consider draining the DEF and replacing it.
Don't you get a "Poor quality DEF warning" if its bad?
Thanks @Viktorrocks15 if you are still out there.
I followed your instructions and worked out great, went to the scrap yard and procured 2016 escalade cluster, hud, bezel, and switch. Got lucky and found a Camaro in the u-pull with the HUD bezel.
I made my own harness with these diagrams:
https://www.gmupfitter.com/wp-content/uploads/2022/10/23_Escalade_Escalade_ESV_Electrical_Body_Builder_SM_en_US_2022OCT25.pdf
I used escalade cluster because its the best one that will work IMO. Still need to get it programmed but it looks really good.
Mine worked fine until I got an update also. After that sometimes it would not connect and Id have to turn CarPlay off and then back on for it to try to connect again. I think I have had two additional updates since this started and it has gotten better but still not perfect.
Register a new accountSign in
