On 8/24/2023 at 2:20 PM, Gator888 said:
Possibly related to a power back feed, do you have solar panels on the trailer? Check out this thread:
This is the exact issue!!  I found someone who posted they thought it was something to do with the battery & solar panels.  On our last trip, the message never happened for 4.5 hours.  After camping all weekend with shore power, we pulled out and started driving home.  Within an hour, the trailer disconnect message started up (as a side note, I have 2 -200W solar panels and it was full sun at the time).  I pulled over and put the battery in to disconnect using the switch and it IMMEDIATELY stopped.  For the next 3.5 hours, it was flawless.  THANK YOU very much for posting this!  I'll send this to the camper dealership tomorrow.
Edited by Lance S
9 hours ago, Garry S said:
Brand new 2024 Silverado 2500HD & brand new Pinnacle 5th wheel with same issue. Looking for suggestions of where to begin diag. Thanks.
Known issue.  GM has a fix.  Ask your service advisor to check GM bulletin 23-NA-149
I have had this ongoing issue with my 2020 Silverado 1500. I have not only had  the Dealership check it out at least 3x (with and without the trailer attached), and additionally, took the Trailer to Gen.RV to have it thoroughly checked out 2x. I also had an independent mechanic check it out (no results other than, "take it to the Dealership") and a retired auto electrician who happened to be at the same campground as me and heard my frustration being voiced. Ultimately, this seasoned engineer spent two full days putzing on my truck/trailer combo and tested everything. He was able to print a very thorough GM document (not sure where he found it.. didn't look like just a plain internet search), which demonstrated that GM CLEARLY knows this has been an issue with MANY of their trucks! I have now officially opened a complaint case with GM. I explained to them that THEY know there is a problem and when my electric brakes give out sporadically, leaving no warning, there WILL eventually be an accident and THEY will be held liable. This is very frustrating for MANY of us. Please, open a case with GM so that they do something.. a recall.. anything. This is so dangerous!
  • 1 month later...
Went thru this list of (23 NA 149 & found lots of engines except 6.6L Gas.
Maybe I missed it, but the fixes were eliminating wear & grounding of wiring in the engine compartment. Couldn't find similar conditions along the wiring to or from the RV plug or controller areas.
Ours like those getting the DIC check trailer wiring message etc. Varies when & where. Metering the plug & socket shows various conditions. One regular "cause" but not always, is slowing coming into a small town. The 1st-3rd braking will pop up the DIC warnings. Then jumping out & chasing that rabbit (shaking the, plug, repluging, measuring voltage in jbox, any touching the circuits) causes it to go away or sometimes come on. Never long enough to track it down.
Replaced the plug, cleaned everything. Started about 2k miles ago & fails mostly going down a grade. But also happens going up hill or on the flat @ any speed
2020 denali, & 2020 keystone cougar bumper pull.
47,k on Denali & 60k on trailer.
  • 7 months later...
I was having the trailer disconnected  message frequently on my 2020 sierra. Noticed that during a trailer light test, that a relay was clicking near the hitch on the truck. It was coinciding with the disconnected notification.  So I set out to check exactly when the disconnect notification occurred in conjunction with every ltg condition.
I found that when the tail lights were on, either turn signal caused the disconnect notification.
( Turn signal denergizes tail lamp during the flash)
So upon googling I came across a GM bulletin that showed the trailer control module uses the tail lamp circuit to monitor weather a trailer is present! It has a high enough wattage threshold that may or may not be met by low draw LED bulbs. My camper is a pre LED era  model, and when I first bought it had upgraded all lamps to improve efficiency and eliminate the heat.
So I swapped out the 1157 tail bulbs to incandescent originals and Wallah....the issue is resolved.
Attached below is the GM info.
I hope this helps some folks.
GM needs to fix this issue. Obviously the engineers set the trailer monitor wattage threshold too high to allow for the lighter LED wattage.  It causes a potentially dangerous condition as it disables trailer brakes and lights when it occurs.
https://static.nhtsa.gov/odi/tsbs/2022/MC-10208985-9999.pdf
  • 1 month later...
2016 Denahli HD, puling 27' 5th wheel, or a car hauler. This trip started out at 72 degrees. Three hours later it's 78, and check trailer wiring message repeats, sometimes every 3 seconds. Had the message once as I was unhooked, about to park it for the night. No longer blame the 5th wheel, but have no clue!
  • 8 months later...
This module 381-7075 from Hydrastar fixed my issue. Talked to the guy at the Hydrastar and he said they have had a ton of success with them. Super easy to install, took 5 minutes.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
