As a lifelong GM fan, I have been back and forth about purchasing either a GMT 800/900, also considering a 2015+. I have recently re-kindled this search only to find myself utterly perplexed in how the interior design could remotely have received any type of approval. This applies to the LWB, not the Tahoe in which all solid-axle Tahoe/Yukon models have an utterly useless 3rd row unless you like your knees in your chest.
With that being said, these are for the most part spacious, people and cargo movers, focusing more on the people side. These vehicles are over 2 feet longer than a Toyota Highlander and have less knee and leg room. I was shocked to find out the 2nd row seats cannot move fore and aft, the 3rd row passengers need to get their foot placed between the seat mounts of the 2nd row seats with very limited moveability.
In addition, the 3rd row seats backs are fixed in the Suburban / Yukon XL offering no additional reclining feature,
I get the fact the rear cargo room is vastly superior to many vehicles, but perhaps leave that to the owners to recognize if they are transporting a higher bias of people or cargo on any given outing. This way the owners can allow more leg room to the passengers.
Sure, the 3rd row isn't geared to people that are 6.5+, but the foot room is horribly inadequate for a vehicle of this size, pic included.
Suburban 3rd row leg room and is fixed.
To compare this to the Highlander, there's no obstructions for the passenger's feet, and there is another 3" of leg room avail if needed. For the record, I will own a Suburban over a Highlander but this is to document how poorly these LWB GM vehicles are configured.
2015 Highlander 3rd row legroom with 2nd row seats in the middle position. The seat only looks close to the floor but had adequate clearance, more than a Tahoe so your knees aren't folded into your chest.
I don't understand why GM didn't incorporate the 2nd row seats to move fore and aft. There's no denying the fact this platform has served many people and have few complaints, there really isn't much competition to the Suburban/ Yukon XL. Yes, I'm late to the party and it just never occurred to me that the interiors were so poorly thought out given the interior volume, So this is just a rant and maybe they can figure this out in the future.
Feel free to add any input and criticism.
Edited by Dkd71
Content
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
