XM
MCourson
Looking to put the Xm setup in the '03. I am going to use the Delphi Sky Fi reciever and I also want to be able to get the boom box for home that uses the Delphi unit too. What all do I need? Stock 03 non Bose RDS single cd player.
Thanks
you need the FM modulator and car kit unless you want to use the cassette adapter that comes with the car kit.I have the boom box too and I know you will love it :sigh:
I got the Delphi Ski Fi for the wife and she loves it. The only problem is where to mount it. So it is sitting in her cup holder for now, till I can find a place to mount it. I tried plugging it into the RCA jacks on the DVD player and it sounded worse than using the Tape adapter. That really tripped me out. I thought it would sound better running it through that RCA inputs, but it picked up engine noise and was lower in volume. Go figure. The antenna was really easy to mount, magnetic mount. and ran it right down the window channel and through the firewall to the dash. Now to get another antenna so I can put it in the truck on my long drives back home to Pa. :(
You can get the Delphi Roady kit now which is 119 and has the car kit and has an available home kit now.
At best buy you get the home kit free when you buy the Roady Kit till this saturday
I would highly recommend looking into doing something other than FM modulation. My Sirius setup runs through FM modulation and the sound quality is not that great. SoundGate (www.soundgate.com) just came out with a couple of modules that allow you to directly connect a Kenwood Sirius or Pioneer XM unit directly into a 2003 stereo. They are the only company that I am aware of who makes such a device. I ordered it last week, and it is supposed to ship on Thursday. They literally just went into production this week. I can't wait.
There's another company that makes auxillary inputs for the 2003s (PIE) but their units require a slave unit, i.e., you must have a factory-installed external CD changer, tape player, or DVD system in your truck.
The Delphi Skyfi system looks really nice, and the user interface of it is quite a bit cleaner than most other sat receivers. I would not buy it unless its possible to run it without FM modulation though.
BTW, pics of my Sirius install can be found at http://www.catastrophicerror.com/~endo/z71
If you look at the FM modulator is underneath the satellite receiver, mounted vertically. It just barely fits. I'm sure the FM mod unit will fit fine in the garbage though :(
Thanks for the help guys. I have pretty much decided on the Delphi SkyFi kit. Does any one have a pic and perhaps measurements of the XM antenna location on stock XM trucks? I would like to have it in the stock location but the guys installing it want to put it by the 3rd brake light. :(
The new Delphi FM modulators work fine..I have it installed in two vehicles and believe me it's better than the cassette adapter.Makes a much cleaner install.The only better sound quality option is if you are changing out your factory deck.
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
