Hello.
I live in Israel . As we do not have a regular import of full size suv's ...info regarding this vehicle s in very lacking...so...I am
Considering on purchasing a chevy suburban.
Options are limited.
2009 1500. 5.3L . 240k km.
2003 2500 8.1L. 170k km.
A friend mentioned that suburban in general is suffering from major transmission problems and that I should definitely stay away from it.
I did find many compliments regarding transmission issue and reliability over the internet. But yet ...also a lot of very possitive and highly recommend reviews especially regarding the 4l85e ..as I understand Is matched with the 8.1L from 2003.
So is have two questions.
With one should I prefer. The 2009 1500 as it  is a newer model.
Or the older model with a stronger build.
Would some one shed some light on the transmission reliability in both models.
Thanks a lot
Daniel
Edited by Daniel Farin
If you are ever going to tow anything go for the 8.1.
I own two of them and will keep them as long as possible.
However the best mileage I have ever received is a little over 12mpg not towing.
As far as I know the transmission problems are with the newer 8 and 10 speed transmissions.
I would personally buy the 2003.
The 8.1 is a very solid engine,  but the mileage is poor at best.
Another thing to keep in mind is that a 2009 5.3 could have AFM where it shuts off some of the cylinders to get better mileage. This system is highly troublesome and requires a pretty significant overhaul to fix.
The 4L60e in the 2009 is a good transmission but lots of people (me included) have had issues with durability and longevity. Overheating the transmission is also a concern.
The 4L85e in the 2003 is a better transmission especially if you plan to pull a trailer or lots of cargo.
The 2003 will also be on a heavier duty frame and axles because its the 2500 instead of the 1500.
2009 Suburbans have the 6L80 transmission, not the 4-speed.  Both transmissions are very stout.  One truck is six years newer, newer gaskets, seals, etc.
