Can someone please help me out with my truck stereo wiring diagram. I'm trying to install an aftermarket stereo on a 2006 GMC Sierra 1500 with bose audio system.
the best advice I can give you is leave your stock wiring alone.  Purchase an adapter that plugs directly into that harness and then you only need to only to wire your adapter for your radio, which they will give you (usually) Here is something you will need most likely if you want everything to work as it should.
The first is the interface adapter
 https://www.amazon.com/PAC-RP5-GM11-Replacement-Interface-Navigation/dp/B07W8X76FL/ref=asc_df_B00DHUA9VA/?tag=&linkCode=df0&hvadid=312050280935&hvpos=&hvnetw=g&hvrand=10908300850449398951&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9026745&hvtargid=pla-435213456377&ref=&adgrpid=61716360643&th=1
It is pretty pricey but this retains all of your options that come factory with your truck, such as radio staying on for a time even after you turn your truck off, onstar, etc.  You can go with just a adapter and do a few wiring tricks, that I can help you with, if you want, but you will lose those functions that came with your truck.
From here you will need only visit your aftermarket stereos website for its wiring diagram which usually is on the radio.  If yours did not come with an adapter for that you will need to purchase one.
acc. switched and amp turn on is all low voltage data controlled.  please follow sharpz recommendation and look for a interface module save you the headache. Or just bypass the amp and rerun all new wires then you know you connected the correct wires.
The adaptor/interface module is the way to go, especially if you have steering wheel radio controls. Installed a Pioneer DVD player in my '04 Silverado, which has steering wheel controls for radio, and am quite happy that I did. Now can change stations or volume without releasing steering wheel.
Hi thanks everyone for the info.
My truck does not have a steering wheel control for the stereo nor an on star system, is a 14 wire delphi connector. I purchased a DKGM-48D interface and turbo-wire connector that suppose to be compatible but it came with 24 wire not 14 like the manufacturer one.
seems like the wrong wiring kit was purchased. that one you said seems to work for the newer 2007+ gm vehicles. if you are wanting to retain the bose amp this should work. or a complete rewire will ensure you have sound with the aftermarket radio. stating you do not have onstar doesn't really matter since the bose amp is in the vehicle. most of the integration kits  will include onstar retention paired with the bose sound integration.
https://www.amazon.com/Metra-GMOS-OnStar-Interface-Systems/dp/B000980HC4/ref=pd_sbs_3?pd_rd_w=9txbm&pf_rd_p=98101395-b70f-4a52-af63-8fac2c513e02&pf_rd_r=0Y6W4XGX3CNQNB0K2BGZ&pd_rd_r=1f362489-dbd2-481e-a37e-2dd1d55b2dcb&pd_rd_wg=RqF7q&pd_rd_i=B000980HC4&psc=1
    lanaderay
    lanaderay
  • Who's Online   4 Members, 0 Anonymous, 1,532 Guests (See full list)
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
