Hey there-
This screen just started popping up over and over and over. No matter what button I select it keeps coming back.
How the hell do I make it go away?  Forever. It’s driving me nuts.
Thanks
just click enter password and enter your onstar/my chevrolet password. mine pops up from time to time . my truck and my wifes blazer are on my onstar account, sometimes when they are both in the garage seems like the key fobs and each car gets confused and thats when it asks for the password, i never tried to figure out why it does it cuz its generally fine for a long time until they get confused again.
Thanks-  I can’t remember the password lol!
LOL ,you know, that is getting to be a big problem. we finally bought a couple of alphabetized password books and write everyone down. i was just gonna use my phone to store them but then i thought a old fashioned paper book would always be better.
  • Haha 1
you can reset your password on OnStar's site
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
