I was flicking through my info menu today and wondered what the value was in some of the indicators.  I’m comfortable with the oil monitor.  It says I have 67% left, and I feel like the ability to monitor and calculate that is pretty good. Engine time, rpms, time in general (months . . .) seem pretty good indicators of oil usage.  But now I see an indicator for brakes and cabin air filter.  Does anyone have any faith in those?  I guess knowing my brake pads are at 50% would be useful, but I wouldn’t trust the indicator over just looking at them and having someone look at the brakes in general when I get the tires rotated.  And the cabin air filter?  I can’t even think if a indicator for that.  Air pressure?  I’m doubtful there’s a monitor of that.
Not sure if I’m missing any others, but in general, does anyone trust these things or find them worth anything in terms of helping you maintain your vehicle?
Ain’t worth much to me. I got off on the wrong foot with the brake pad monitoring system. When I first bought the truck there was a software glitch that would cause it to drop to like 20% after only a small amount of miles. Update fixed it but I wouldn’t rely on it.
For what it’s worth, the brake life is calculated via an algorithm but there are also pad wear sensors, one front and one back. So it theoretically could be accurate.
I don’t have the cabin air filter monitor on my 19, just engine air filter.
Have a 2021. I belive the oil life monitoring is pretty good. I good above and beyond with 5k changes. It says I have used 8 percent of brake pads over 10k miles I agree with that. Engine air filter seem a little weird to me mine was at 90% at 10k miles, there's no way I would go 100k on an air filter. I also drive on dusty jobsites sometimes.
The filter monitor is for the engine air filter, not the cabin filter.  There is no monitor for that.
The air filter monitor is based on driving conditions but I can't find anything specific.  More than likely, its measuring for any restriction in air flow across the MAF.
Pad wear indicators are good, but only measure the inboard pad on the driver's front and rear wheel.  So if there was pads froze up in the caliper on the right side and are worn down further, you'd hit the squealer on the right before the wear sensor on the left.
The wear sensor measures the air gap from the sensor head to the rotor surface.  As the gap closes, the percentage falls off.  As long as the pads are moving freely and the sensor is kept clear of debris, it would work as designed.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
