I have a 2021 Silverado and every time I start up my truck, it connects wirelessly to my android auto. When it does this it stops my radio (I keep it on XM radio 99% of the time) and it switches it voice command for some reason. It took me forever to figure out what was going on because I couldn't hear any audio from my infotainment center. I finally figured out that it was on voice command with no prompt telling me. The only way to get it off voice command and back to my radio and functions is to press the voice command button on the steering wheel and then pressing the cancel button right under it. Has anyone else had this problem or does anyone know how to stop it from happening? I have changed all known settings on my phone and truck that would make it stop, but nothing has worked.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
