2 hours ago, Th3 Lost Dorito said:
can you take the suspension off of a 2014 3500 sierra/silverado and put it on a 2014 sierra 1500?
You can do anything with enough money.  This is not a direct swap, fabrication would be required.
When you say suspension. Do you mean coil and springs swap?
They sell after market upgrade for the coil and springs for the 1500.
the entire suspension
pretty much like take the body off a 1500 double cab and drop it on a 3500 double cab
Anything is possible if you have enough money, time, and talent to do it.
