I wonder if anyone knows this one, I have a 2019 High Country, and my friend just got a 2021 High Country, his backup camera is so much clearer and much more crisp than my 2019 backup camera. It is a HUGE difference. I'm wondering if it is the camera of the radio in which is making the difference and can my 2019 be upgraded? Ideas?
Hello Eppieguy!  I, also had a early-build 2019 High Country,I traded that off a few months ago when the trade value exceeded my patience dealing with some ongoing issues, and I ended up with a new 2021 High Country.  I also noticed the difference in the cameras, and from what I've read here and elsewhere, its not just a camera issue, its a radio issue. There is some difference in the camera architecture in the 2019 version that changed in 2020 when they added the upgraded camera tech (bed camera, invisible trailer camera).  White Automotive https://www.whiteautoandmedia.com has been doing some updates in this space, but I remember reading on their website there are several considerations before you can simply upgrade a camera.
    • 2026 3500HD.  Mostly empty. Grocery getter. What tire pressure are you running for 37x12.50x20. I have 37x12.50R20 Toyo Open  Country RT pro and been running around 55 lbs front and rear and it's too much. Tires are wearing more in the middle. Toyo says 45 front and 50 rear. Chalk test and it's still too much. I lowered it to 40 front 44 rear see what happens.
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
