I bought a taken apart gen vi 454 L21 vortec engine block, crank, n rods/pistons. The guy who took it apart didn't label what cylinder rods/pistons came out of.
The rods/pistons are still assembled together but how do I tell what cylinder each came out of? There are many factory marks on inside of pistons but nothing obvious (to me). On the rod cap sides(both upper n lower)they have unique stamping marks.They are:
T053
V028
V272
X225
M029
L290
X254
L147
What does the stamping mean? Hopefully that translates to a certain cylinder or something.
Thanks for your help!
Unfortunately, you're pretty much out of luck there. While it's not ideal to mix n match pistons and cylinders, it will still run. Hopefully it's not worn out to the point where it smokes. I suppose you could measure at least 6 points on each piston and cylinder, and match them up with whichever has the correct clearance, but with taper and everything that may be tough.
If it were me, I'd buy a whole new set of +1 or +2 (depending on what's in there now) pistons and rings, bring all of that plus the block to a machine shop and have them bored to match. Since it's already apart, that would be you're best bet. The engine will run PERFECT, and stay that way for a LONG time. Every piston/cylinder will be equal and to proper clearance. Finish it off with a new oil pump, and that engine will be ready to rock for DECADES to come. Every one of those  engines makes it 250k miles at a minimum without ever going into the engine, unlike most of today's junk. You may have to replace lifters or valve springs down the road, but that's a weekend job, instead of 20 hours labor just to reach them on an LS.
The stampings are just to match the end caps up - that's critical. Can't mix and match end caps. That brings us to another problem - which rods went to which journals? You're going to have to get some Plastigauge and do some clearance measurements.
Edited by Jsdirt
Forgot about the stamping question ...
Jsdirt: While not on topic my question remains on point. Not intending to derail this thread just looking for parallel information.
Why does GM think this is not an issue with the Ecotec 2.4 I4. TSB on the critter has them putting new pistons and rings in a 100K mile block without so much as a hone. In fact they say not to hone.
So the question is, how successful has this been in eliminating oil consumption?
Was the strangest TSB I ever read. Defies everything I know about motor building.
Yep, totally defies logic. Must be a warranty job, otherwise they'd have everyone do it right.
The other reason for that could be if there's some coating on the cylinders, like Nikasil - Japanese motorcycle manufacturers used to do this in the day. You couldn't hone or bore, since it would wipe out this coating. Only cast pistons could be used, too, if I remember right, or they'd seize. I highly doubt GM would spend a nickel on this process, though. It wasn't cheap, even for single cylinder bikes.
If that were my car & I wasn't a tech, I'd take it to a private garage and have them do it right - take the block to a machine shop and hone each cylinder to as good as they can get it. Or buy +1 over pistons and have them matched (ideally).
I don't have any experience with that engine - most of my customers are truck or SUV owners. Very few cars.
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
    • get a good code reader, and find out what problems the truck has noticed by reading codes. cheap ones can only get basic engine codes, you may want to get one that can get codes from all the computers in your truck.
    • This is sort of my point, salvage yards aren't overflowing with all these 'poorly' maintained trucks - excellent/good/servicable condition otherwise, salvaged only as a result of a bad engine from poor oil change regiment.    In my area, there are no 2007 to newer gm trucks/suvs in any salvage yards. A few are in the 'recyclers' with very obvious reasons for being there - wrecked.
    • Stabilitrack was a stability control, traction control system, that functioned independently from the transfer case.   Z-71 has nothing to do with the transfer case or differential.   If it does have an AWD system, my memory recalls this being specific to the Denali trim, converting won't be as simple as swapping out mechanical parts like differentials and transfer cases. It will require reprogramming at a minimum. Long story short, not likely worth it.   Pulling a fuse, may disable the AWD system, it might also prevent any other transfer case functions.   However, the AWD case was generally based on the same transfer case you refer to in the 2006 Suburban. If it still has a 4-High and 4-Low where the transfer case locks and splits power 50-50 front to rear, what are you gaining by changing anything? A true-rear wheel drive only, what good will that serve? Not enough to go through the trouble of changing out all the parts.    Generally, all the factory systems will handle a 33" tire and re-gearing. Probably a 35" tire too, if you aren't driving like a caveman. If 35" tires are in the plan...   If you do plan on driving like a caveman or are fully committed to 35" tires, an entire re-think of the build is probably in order. Starting with square one, an IFS front end isn't going to be the best starting point for 35's and caveman driving.
    • 1/2 qt over full ain`t gonna hurt $h!t. Most times, a whole qt won`t either. Most have windage trays now. As long as the crank isn`t slapping itself in the oil, it`s not the end of the world.   We used to overfill 1 qt at the track, at race time. Better to have it over full than having the pan sucked dry at 6500 rpm`s.
