Hi,
I have 2018 Silverado 1500 black widow Edition. I bought a pair of D5S replacement bulbs only to find out there is no access on the headlight housings to change a bulb. I watched all the you tube videos that shows a “dust cover” that your remove to access the bulb to change it, however my truck does not have a removable cover, it a a solid plastic housing. I even removed the whole headlight assembly from the truck to see it there was another way to access where the bulb would be and there wasn’t any. I’m stumped, do you have any information on what the deal is with that?
Thanks,
Do you have the "T4L" - HEADLAMPS, LED PROJECTOR WITH SIGNATURE DRL AND TURN?
Just curious, are the LEDs replaceable?
Not sure what t4l is? They are projector led, with drl and trun
Edited by Maxx16
That's the RPO code for the LED headlights. You find that number on the RPO card in the glove box.
So, does your truck have LED headlights from the factory?
No RPO code sticker in the glove box on the 18's. That is how they started saving millions in dollars🤔
We have a QR code sticker in the door jamb, which shows about 75% of options on your smart phone.
LED's (at least the turn signals/park lights) are not replaceable, one and done. Whole unit needs to be replaced.
Edited by JimCost2014
Yes there led from factory. Crazy chevrolet has you replacing the whole headlight unit when the bulb eventually goes out!
Did your bulb burn out or were you trying to up grade? Is it possible to drill a hole where the rear cover is on other lights & replace the old one?
Think he meant to say whole headlight unit. Can not just replace the LED bulb.
Whole thing goes into garbage.
Never saw an LED light burn out yet myself. I've seen broken solders (cheap chinese), dead batteries(flash lights) but have yet to have a LED burn out on me yet.
Do you know why you can't repair rather than trash one expensive light housing? I've seen the led taillights being repaired. Maybe a good side line business.
    smandy
    smandy
  • Who's Online   2 Members, 0 Anonymous, 536 Guests (See full list)
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
