So I have a 2006 Silverado Work Truck and I am doing some upgrades. I didn't think they are too difficult but I have an issue. I cannot communicate with the BCM after adding the RAP wire that was missing on the controller plug to turn on my after market radio through a relay relay. (I wired in the relay and the BCM actives it as expected)
It has the crank but no start issue. When the Key is activated the Security Light show's for a few seconds on the Dash and then goes off as normal.
All the basic BCM functions appear to work, doors activate the overhead light, Auto Headlights, AC engages, but this is a work truck so there is little else except the Passlock2.
I have tested the power wires to the BCM all test good.
I have tested the ground wires to the BCM all test good.
I have used the Tech2Win software on my Laptop. I can see various modules which are active, but the BCM is missing.
I have programmed the HVAC, PCM, IPC, and other modules with updates from the ACdelco SPS website, all complete with no problems.
So my next thought is to disconnect all the wires from the BCM except for the Power, Ground and Serial Wire to verify if I can get signal?
I have some extra pigtails for the BCM I took out of a LKQ Chevy Truck of the same year when I was gathering parts.
I also have a question on BCM Programming, watching a YouTube video I observed them programming the BCM by going to the Radio then selecting the BCM as a drop down.
My truck is a work truck and has an aftermarket radio, so I don't think that's the way it would program? or is it?
I'm scratching my head on this one. Any help on where to look or what to test is greatly appreciated.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
