I have a Liftmaster 8500 on my shop door and a Genie 1055 on my garage door.  I had to get a Car2U Repeater to get the Liftmaster to program to my 2013 Silverado.  When I tried to program the Genie to another button it failed.  I cleared the openers from the truck buttons and was able to program the Genie, but when I tried to program the Liftmaster it failed.  I cleared the openers again, programmed the Liftmaster and tried to program the Genie with the same failed results.  I've tried unplugging the Liftmaster and Car2U thinking the two openers were in too close proximity and there was some interference happening.  That didn't work either.  Anyone else run into this situation?  Thanks.
  • 3 months later...
Not exact. I had issues with the Car2U and replaced the garage/Lear opener in the overhead console with the Homelink module from a 2014 Impala. Works with all garage openers. I’ll pull it down this weekend to show difference in design/plug.
    • So, my 2021 only gets radio updates, right? If that's the case, my radio is doing just fine and probably better off without any updates, especially considering the problems I've been reading about after updates were performed.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
