I purchased a 2021 Silverado 6.2 LTZ Z71 2 weeks ago and traded my 2018 5.3 in for it. They've replaced the ECM, oil pump, some sensor and they are still getting a check engine light. All of this is still before I took delivery of it. As of today supposedly a GM engineer is coming out to look it. I am really discouraged in the new product.
Wow. Since you have not taken delivery of it..... do you have to ?
lawyer up !!!
Yotaman
Lol how did it break before even taking delivery, that is a new one to me. In any case the market is so poor right now, inventory wise, that i wouldn't doubt you can take delivery and possible flip it for a little profit right now if you get buyers remorse on it.
I'm thinking that, they prayerfully caught whatever issues on their time and they get them resolved and I can take delivery and have some piece of mind. Wishful thinking.
I suggest that you find a different truck, think about it, if it already has all these issues what else could be coming down the road? It’s probably a bad apple, walk away, you are better off dealing with the headache of finding inventory elsewhere rather than wondering if your “new” truck is going to hold up for you.
What happened to the brand new/delivery experience? We deserve it when spending $40k+
Heck, mine is a 5.3 and after multiple flashing CEL and P0300 codes, I got a new engine at 1600 miles.  Now at almost 4,000 miles and I am about to uncross my fingers.
lawyer up !!!
Yotaman
Hopefully shouldn't need to lawyer up.  If he hasn't taken delivery can unwind easily.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,252 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
