Google search does show replacement inserts, if they fit your wipers is another question.  I picked up some aftermarket wipers, but saw OEM wipers (not inserts) on RockAuto for about 40 bucks for the front set.
17 hours ago, Mikey999 said:
Is 2018 suburban  able to replace  wiper inserts as opposed to the whole  wiper blade?
NO.
Rock auto sells wiper blades for very low prices compared to local auto parts stores. Purchase enough for 2 or 3 years at once to save on shipping charges. They have many brands to choose from, Costco also has good prices on blades.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
