I belong to 6 online forums. This site is the worst for problems. This morning it wouldn't load or error 520.
Just sayin.
Just sayin.
Yikes!! When do you have time to eat?
  • Thanks 1
  • Haha 3
I am not active on a lot of forums but have participated in a few.  I haven't found this one to be particularly problematic.  I've had the error message but  is resolved by a brief wait and trying again.
I tried 4 times and waited each time. Closed my browser to.
Everything else worked fine.
I have had the 503 redirect error a few times as well. Like Donstar I wait and it goes away. Waiting may mean doing something else for awhile...like mow the lawn but 😉
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
