Fresh from the other day.
2022 Silverado 1500 LTD - Model Information - Online Ordering Guide (gmfleetorderguide.com)
2022 Sierra Limited - Model Information - Online Ordering Guide (gmfleetorderguide.com)
What's new/gone/changed for Silverado:
Chevrolet Truck Silverado 1500 LTD
Deletions
 (LV3) 4.3L EcoTec3 V6 engine
 (L82) 5.3L EcoTec3 V8 engine (NOTE:  This means no 5.3 on Custom and Custom TB)
 (FHS) E85 FlexFuel
 (MYC) 6-speed automatic transmission
 (BD1) Custom Max Trailering Package
 CK18753 Double Cab model on Custom Trail Boss (2CX)
 (C67) Air conditioning
 (5VI) LPO, Cargo tie-down rings
 (VBR) LPO, Rubber bed mat
 (SIE) LPO, Tiered storage
 (N06) Steering column lock
 (U2L) HD Radio
Changes
 (L3B) 2.7L Turbo engine is now standard on Work Truck (1WT), Custom (1CX) and Custom Trail Boss (2CX)
 (L84) 5.3L EcoTec3 V8 engine is now standard on RST Crew Cab (1SP)
 (L84) 5.3L EcoTec3 V8 engine is now available on Work Truck (1WT)
 (LM2) Duramax 3.0L Turbo-Diesel I6 engine is now available on LT Trail Boss (2LT)
What's new/gone/changed for Sierra:
GMC Sierra /Denali 1500 Limited
Deletions
 (C67) Air conditioning, single zone
 (FHS) E85 FlexFuel capable
 (U2L) HD Radio
 (PCJ) Off-Road Performance Package
 (PDM) LPO, Performance Upgrade Package
 (5W7) LPO, Performance Air Intake System
 (N06) Steering column, lock control, electrical
Changes
 (R3O) LT275/65R18C MT blackwall Goodyear Wrangler DuraTrac tires are standard on AT4
 (L3B) 2.7L Turbo engine is now standard on 1SA
 (L84) 5.3L EcoTec3 V8 engine is available on 1SA
 (L84) 5.3L EcoTec3 V8 engine is not available on AT4
 (LM2) Duramax 3.0L Turbo-Diesel I6 engine is standard on AT4
 Battery, heavy-duty 730 cold-cranking amps/80 Amp-hr is now standard on 1SA
 (C4P) Air conditioning, Semi-Automatic standard on 1SA
 Changed (PEC) Denali Ultimate Package name to Denali Reserve Package
 Renamed 1SA trim to Pro
 (WBC) LPO, Cat-Back Performance Exhaust is available on 3SA, 3SB, 4SA, 4SB and 5SA with (L84) 5.3L EcoTec3 V8 engine
 (KA6) rear heated seats have moved to an available option on 4SA, 4SB and 5SA
Edited by newdude
To add to this.
The model codes are now different for the 2022 LTD/Limited (aka pre refresh T1) to identify them over the 2022.5 refreshed trucks.  Currently for example, a crew cab short box is designated as CK10543 (Chevy) or TK10543 (GMC).  These LTD/Limited trucks drop the "0" for an "8".  So a 2022 crew cab short box 4x4 will be designated as CK18543 (chevy) or TK18543 (GMC).
To me, it seems to be semiconductor and refresh related cuts.  HD radio and the column lock are semiconductor cuts.
The Custom Max Trailer is axed because the L82 and 6 speed are gone.  4.3 is dead which I think Zane had a piece on earlier this year.  Must not be a lot of AT4 with the 5.3 sold as the 3.0 diesel is now standard on it with the 6.2 as optional.  Double cab Custom TB might be sales related?
Yeah, I figured it was a good move as most people who buy AT4s either buy them in the 3.0 or the 6.2. It's also good to hear that they added 3.0 as an option for the Trail Boss, as that was one of the reasons I wanted an AT4 instead of an LT Trail Boss. It seems that they're still offering the 5.3 on the Trail Boss tho?
Yes.  Custom Trail Boss loses the 5.3 and 6 speed option however.  Standard will be the 2.7T and the 6.2 optional.  The LT Trail Boss is 5.3/8 speed standard, diesel and 6.2 options.
Yeah the oil burner in TB is a nice move.  And interesting that a diesel motor is standard now on AT4. How much extra is the 6.2 option then on AT4?
And if I’m reading correctly the 5.3 with AFM is now only available on WT?
On 7/16/2021 at 8:22 AM, newdude said:
To add to this.
Thank you for the info and really thank you for always providing great info. Based on your knowledge the refresh is still a go for 22 model right. ?
I read it as the L82 AFM 5.3 is completely gone, and they've added the L84 DFM 5.3 to the W/T, but not Custom and Custom Trail Boss
The MCE aka 2022.5 should be end of 2021/January 2022 from what it sounds like.  We should see info on it in late summer so August/September.
Edited by newdude
corrected estimated 2022.5 info date
  • Thanks 1
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
