All,
So my 2007 Silverado had a check engine light. P0446/Evap vent circuit. I have done the following:
1.) Tested vent valve solenoid 25 cycles with a 12V battery charger. Functioned correctly.
2.) Tested purge valve solenoid 25 cycles. Functioned correctly.
3.) Removed hose to vent valve. Blew into it. Held thumb over it for 60s. Air whooshed back out.
4.) Gas cap gasket looks good. I put a little silicon oring grease around it just in case.
I replaced the vent valve solenoid thinking it might be failing intermittently. Still getting the P0446. The system does not seem to have any leak, unless it is very minor (or I would have thought the pressure I blew into it would have bled off).
I am guessing it must be the pressure sensor on top of the gas tank. I don't have a scanner to read real time values on that, though. I read that the WIFI ELM 327 OBD (about $20 on Amazon) will work with a phone with app iOBD2 and provide that real time pressure value (but not sure).
Any thoughts? Buy the ELM or just put a new pressure sensor on it and see if that fixes it? It seems I can feel it over the LHS frame rail and I think it just pulls out.
Thanks in advance!
The proper way to diagnose this is with a Tech-2 and a gas cap adapter and smoke machine.  Since you've already replaced the vent solenoid, you might want to put a new gas cap on (they just don't only leak from gasket) before replacing the pressure sensor.
From the shop manual:
DTC P0446
Evaporative Emissions (EVAP) Vent System Performance
TYPICAL SCAN TOOL DATA
FTP Sensor Signal Voltage                                             Fuel Tank Pressure
1.5 V                                                         Atmospheric Pressure/BARO
Less than 1.5 V                                                           Positive Pressure
More than 1.5 V                                                  Negative Pressure/Vacuum
CIRCUIT/SYSTEM DESCRIPTION
This DTC tests the evaporative emission (EVAP) system for a restricted or blocked EVAP vent path
that would cause excess amounts of vacuum to be developed in the EVAP system. With the purge valve
open and the canister vent valve open, if the EVAP system vacuum goes above a calibrated threshold,
the test will fail.
CONDITIONS FOR RUNNING THE DTC
● DTCs P0106, P0107, P0108, P0116, P0117, P0118, P0120, P0121, P0122, P0123, P0220, P0222, P0223,
P0442, P0443, P0449, P0451, P0452, P0453, P0454, P0464, P0496, P0608, P0609, P0641, P0651, P1516,
P2101, P2119, P2120, P2122, P2123, P2125, P2127, P2128, P2135, P2138 are not set.
●  The ignition voltage is between 11-18 volts.
●  The barometric pressure (BARO) is more than 74 kPa.
●  The fuel level is between 15-85 percent.
●  The engine coolant temperature (ECT) is less than 35°C (95°F).
●  The intake air temperature (IAT) is between 4-30°C (39-86°F).
●  DTC P0446 runs once per cold start when the above conditions are met.
CONDITIONS FOR SETTING THE DTC
●  The fuel tank vacuum is greater than 12 inches H2O vacuum for 5 seconds.
●  The FTP is less than -2.5 inches H2O or more than +5 inches for 60 seconds after a cold start.
ACTION TAKEN WHEN THE DTC SETS
DTC P0446 is a Type B DTC.
CONDITIONS FOR CLEARING THE MIL/DTC
DIAGNOSTIC AIDS
● An intermittent condition could be caused by a damaged EVAP vent housing, a temporary blockage at
the EVAP canister vent solenoid valve inlet, or a pinched vent hose. A blockage in the vent system
will also cause a poor fuel fill condition.
●  An EVAP canister filter that is restricted can cause this DTC to set.
●  J 41413-200 EVAP Emission System Tester (EEST)
●  GE-41415-50 Fuel Tank Cap Adapter
CIRCUIT/SYSTEM VERIFICATION
1.   Ignition ON and fuel cap removed, verify that the FTP sensor parameter is between 1.3-1.7
volts.
○  If not within the specified range, go to the FTP sensor section in Circuit/System Testing.
2.   Install the fuel cap.
3. With the engine running, the EVAP canister vent solenoid valve open and the EVAP canister purge
solenoid valve commanded to 100 percent, the fuel tank vacuum should not increase to more than 11
inches H2O.
○ If the fuel tank vacuum is greater than the specified range, go to the restriction section in
4. Operate the vehicle within the Conditions for Running the DTC. You may also operate the vehicle
within the conditions that you observed from the Freeze Frame/Failure Records data.
CIRCUIT/SYSTEM TESTING
IMPORTANT: ● Refer to the J 41413-200 operation manual for detailed instructions in Evaporative
Emission System Diagnosis .
● Perform the Circuit/System Verification before proceeding with the Circuit/System Testing.
Restriction
With the engine running, the EVAP canister vent solenoid valve open, and the EVAP canister purge
inches H2O.
○ If the fuel tank vacuum is greater than the specified value, isolate the restriction by
disconnecting one component at a time while the EVAP canister purge solenoid valve is commanded to
100 percent and the vent valve is open.
FTP Sensor
volts.
○ If the FTP sensor parameter is not within the specified range, test the FTP low reference circuit
for an open or high resistance. If the circuit tests normal, replace the FTP sensor.
2. Connect the J 41413-200 nitrogen/smoke hose to the J 41413-311 brass cone adapter. Disconnect
the hose at the fuel cap end of the GE-41415-50 . Connect the J 41413-311 to the disconnected hose
on the GE-41415-50 . Install the GE-41415-50 filler neck end only to the vehicle.
3.   Start the engine.
4.   Allow the engine to idle.
5.   Use the Purge/Seal function to seal the system with a scan tool.
6.   Command the EVAP canister purge solenoid valve to 20 percent.
7.   Observe the vacuum/pressure gage on the J 41413-200 and the FTP parameter on the scan tool.
8. Verify that the vacuum increases to the abort limit on the scan tool or more than 3.2 volts, and
the value is similar between the scan tool and the vacuum/pressure gage on the J 41413-200 .
○  If the values are not similar, or the voltage is not within the specified range, replace the FTP
sensor.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
